BC Coilover install this weekend
Old Apr 4, 2013 | 07:42 PM
Rasimmo's Avatar
Rasimmo
Thanks for the input guys! I appreciate it.
Posted from ClubLexus.com App for Android
Old Apr 5, 2013 | 11:08 PM
Rasimmo's Avatar
Rasimmo
BC's are installed It wasn't as bad as I thought...considering all my "this is gonna be easy" jobs turn into a 2day project lol car looks good even though its sittin on the oems...next stop! Wheels n tires
Old Apr 17, 2013 | 04:51 AM
Rasimmo's Avatar
Rasimmo
So after 2weeks I've come to the conclusion that the spring rate on the front is too low... The car seems to bottom out on dips and small bumps in the road...especially going around a corner. I tried setting the preload a little better and have the setting 8 clicks from hard and still seems to ride like my springs are cut....any suggestions?
Old Apr 17, 2013 | 10:36 AM
timmy0tool's Avatar
timmy0tool
did you lengthen them out of the box? i found that out of the box they are a bit too short. show us pics of the drop and i can further assess.
when you say "setting the preload" you mean the you spun UP the collars directly below the spring right?
Old Apr 17, 2013 | 11:56 AM
jayntee's Avatar
jayntee
maybe your UCAs are hitting the tower?
Old Apr 17, 2013 | 01:13 PM
usoff89's Avatar
usoff89
^^^^ What he said! The bottoming out sound your hearing is most likely the a-arm hitting the shock tower. Depending on how low you are, you WILL have to cut a hole in it for it to pivot in and out of. I cut about a 4x4inch hole on each side, and it stopped hitting (bottoming out sound).
Oh, and if you are low enough to hit the tower, you also need to move the harness on the driverside. The tire could rub threw it, and you will have a ton of problems.
Old Apr 17, 2013 | 08:15 PM
Dranom's Avatar
Dranom
+1 on the control arm hitting.
Get a holesaw and get to work on it
Old Apr 18, 2013 | 05:27 AM
Rasimmo's Avatar
Rasimmo
Yea I spun the upper collar...
I'll look into this
Old Apr 18, 2013 | 05:31 AM
Rasimmo's Avatar
Rasimmo
I'll post pics in a min...
Old Apr 18, 2013 | 07:03 AM
Rasimmo's Avatar
Rasimmo
Some pics I took the other day
Attached Thumbnails BC Coilover install this weekend-20130410_195707-1-.jpg   BC Coilover install this weekend-20130410_195639.jpg
Old Apr 18, 2013 | 11:32 AM
timmy0tool's Avatar
timmy0tool
you spun the upper collar in which direction? up or down? down would DECREASE your tension thus making your ride softer and making the upper a-arms hit.
typically you do should not even touch the upper collars to adjust height. you use the lower collars for height.
Old Apr 18, 2013 | 12:20 PM
Rasimmo's Avatar
Rasimmo
I know this...lol
Old Apr 18, 2013 | 12:24 PM
usoff89's Avatar
usoff89
Looks good! Even with the stockers, I think the front end would look so much better with some clear marker lights. IMO
Old Apr 18, 2013 | 12:41 PM
timmy0tool's Avatar
timmy0tool
I know this...lol
hehe just checking, you'd be surprised how much people are oblivious when it comes to coilover adjustments. the drop looks great!
Old Apr 18, 2013 | 01:10 PM
Rasimmo's Avatar
Rasimmo
Thanks! Yea, I gotta work on the appearance a lil
