Grinding...
Old Apr 5, 2010 | 09:48 PM
IdkUser's Avatar
IdkUser
Default Grinding...
I have close to no knowledge of cars in general. The 91 LS400 is my first car, and I am very thankful for owning it. The problem is when I am accelerating/decelerating or turning (not sure) something sounds like it is grinding, it just happened while I was driving home today, so I will drive it around tomorrow and see when exactly it starts to have a grinding noise. Sorry for being so ignorant on the cars. Also, does anyone have any advice on a good way to start learning about cars?
Old Apr 5, 2010 | 09:50 PM
Iconoclast's Avatar
Iconoclast
I have a similar issue in that when I accelerate I can hear suspension sound in the front wheels. When I go quicker, the sounds changes with the speed of the wheels, is that what you have as well?
I will be sure to update this once I have my problem diagnosed, I hope it is cheap fix for both for us.
Old Apr 5, 2010 | 09:58 PM
j stuff's Avatar
j stuff
Im just throwing this out there, but is it possible you are driving with your E-Brake on?
Old Apr 5, 2010 | 10:25 PM
IdkUser's Avatar
IdkUser
No, I mean I may be ignorant, but not that much xD. I will drive it around tomorrow and see how it works... I have a feeling it may have something to do with the power steering.
Old Apr 5, 2010 | 10:32 PM
j stuff's Avatar
j stuff
Does it sound like a creaking or cracking like metal going clank clank or something?
Old Apr 5, 2010 | 10:38 PM
IdkUser's Avatar
IdkUser
Definitely more of a creak.
Old Apr 6, 2010 | 01:28 AM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
did you check the PS fluid if you think its steering related...?
Old Apr 6, 2010 | 05:53 AM
IdkUser's Avatar
IdkUser
Um, I honestly don't know how to check the PS fluid... any advice?
Old Apr 6, 2010 | 06:02 AM
Rugster's Avatar
Rugster
You have your owners manual? If you do then read it..
Old Apr 6, 2010 | 07:32 AM
williamb82's Avatar
williamb82
check all the lugnuts and make sure they are tight. the day i bought my ls, the front left wheel made a creaking sound. i was like wtf as it was perfect when i drove it a few days before. pulled the center cap and the lugnuts were loose. so i tightened them and checked all 3 other wheels. never made another sound.
Old Apr 6, 2010 | 03:08 PM
IdkUser's Avatar
IdkUser
Nah, there is a leak from under the power steering. The noise is made when I am making right turns turning the steering wheel more than one revolution. I am taking it to a mechanic tomorrow. Hopefully it is not an expensive fix....
Old Apr 6, 2010 | 04:31 PM
ZeRoSL's Avatar
ZeRoSL
should have read the power steering bible on this forum
LINK: https://www.clublexus.com/forums/ls4...ing-bible.html
Old Apr 6, 2010 | 04:39 PM
IdkUser's Avatar
IdkUser
Oh wow. I really hope none of it leaked into the alternator... and my car has 170,xxx miles on it so it may be time to replace it... I hope its not too expensive of a repair.
Old Apr 6, 2010 | 07:46 PM
j stuff's Avatar
j stuff
Yea im thinkin you're low on ps fluid. Try to refill that and see if it helps a bit.
I believe it is your steering rack n pinion making that sound.
TAP4636
Jun 16, 2021 01:28 PM
ClubLyfe
IS - 1st Gen (2001-2005)
Sep 23, 2017 11:13 AM
Tmntman4
RX - 1st Gen (1999-2003)
Sep 28, 2010 09:52 AM
ShibbySC4
Sep 15, 2010 08:07 AM
stevie
Suspension and Brakes
Sep 2, 2002 12:48 PM
