99 LS400 Shaking Problem
Old Dec 18, 2008 | 11:11 AM
stickyrick's Avatar
stickyrick
Default 99 LS400 Shaking Problem
Hey guys I have a 99 LS and when im on the freeway going about 70-80mph the car shakes, its really annoying. It happens when im accelerating but as i let off the gas it stops? anyone got an idea of what the problem might be?
Also when im on the freeway, sometimes the car will feel like a have a flat tire, then it goes away. It usual comes from the rear
Old Dec 18, 2008 | 11:34 AM
Kansas's Avatar
Kansas
One common cause of vibration at highway speeds is bad front strut bar bushings -- you can see the strut bars in front of each front wheel suspension assembly if you get down on your knees and look. I had the ones on my 00 LS400 replaced at 86,600 miles due to the vibration. On my car, the vibration was almost always apparent at about 65-70 mph but was sometimes worse depending on how much the road was crowned and even whether or not there was a strong wind.
Apparently it is less expensive to replace only the bushings if you are doing the work yourself -- the bushings have to be pressed into the bars if I remember what someone on this forum said. Due to the labor rate I was paying at the Lexus dealer, it was less expensive to buy the complete strut bar assemblies.
steveski's Avatar
steveski
Welcome - some may say engine and/or tranny mounts since it is only experienced with accelerating.
Old Dec 18, 2008 | 08:47 PM
JBrady's Avatar
JBrady
While you may well have bushings/strut bar the FIRST thing I would do is make sure your tires are not the problem.
Most of the vibrating shimmying and comming/going steering wheel problems I have had were due to out of balance or out of round tires or a separated carcas. Check those tires.
Old Dec 19, 2008 | 08:01 AM
steveski's Avatar
steveski
True - should have mentioned that first. If your tire shop can do a high speed balance it would be best. Some shops have road force machines where tires are balanced against a hard surface simulating the road versus a free standing balancer. Recently one shop balanced mine but they were still out. Another shop down the road did the same and they were perfect - differences due to calibration.
Old Dec 19, 2008 | 08:54 AM
stickyrick's Avatar
stickyrick
ohhh ok got it! thanks guys ill have this stuff check out this weekend
Old Dec 19, 2008 | 12:49 PM
Kansas's Avatar
Kansas
Interesting that you brought up balance. I had my wheels/tires rebalanced three or four times within a 2 - 3 month period, including on road force balance machines, trying to get rid of the vibration at highway speeds. I didn't even use the same shop twice.
I finally gave up and took the car to the Lexus dealer. They replaced the strut rods and the vibration was totally gone.
But, for sure, other issues can cause a similar vibration problem.
Old Apr 6, 2009 | 06:47 AM
Horsepwr's Avatar
Horsepwr
Default my solution
I had a 98 ls400 do the exact same thing ,ended up being the transmission mount ,now it's smoothe as silk !!!! Part was $65.00 from Lexus ,and very simple to install .
LexieLS
28
Jun 19, 2017 05:15 AM
davincity
Sep 25, 2014 01:58 PM
trinils97
Dec 3, 2011 07:34 AM
tanyet
12
Jul 24, 2011 05:51 AM
porshapowe
Feb 6, 2007 11:06 PM
