97 LS Timing Belt Install Question
Old Feb 3, 2025 | 10:14 AM
Superfast1's Avatar
Superfast1
Default 97 LS Timing Belt Install Question
Hi there, there's a slight different between the timing belt install of the 90-94 vs 95-97 which I guess it has to do w/ one being non-interference & the other being interference engine. According to the Aisin Timing Belt Kit TKT-030 install instructions that came w/ the kit, for the 95-97, it stated: After turning the crankshaft clockwise until the No. 1 cylinder at TDC & the 2 camshaft's timing marks aligned, turn the crankshaft clockwise another 50 deg until pulley timing mark aligned with guide pulley bolt as shown in picture. I'm not exactly sure what or where the guide pulley bolt they're referring to so can someone explain or point it out for me? Thanks
Old Feb 3, 2025 | 11:22 AM
bradland's Avatar
bradland
The timing pulley (bolt highlighted in red here), you should also see a small mark on the casing just behind the crank pulley.
Old Feb 3, 2025 | 11:35 AM
Superfast1's Avatar
Superfast1
Got it. Thank you very much, Bradland.
One more thing, when I'm ready to do the timing belt, can I get by without moving the AC compressor to one side?
Old Feb 5, 2025 | 03:37 PM
timmy0tool's Avatar
timmy0tool
it's been years but from what i remember, i never touched the ac compressor when i did the t-belt job!
more (for a 1st gen but very similar on the 95-97)!
http://www.lexls.com/tutorials/engine/timingbelt.html
Old Feb 5, 2025 | 05:21 PM
paulo57509's Avatar
paulo57509
The AC compressor mounting bolts need to be removed in order to be able to remove the fan bracket.
Old Feb 5, 2025 | 06:26 PM
Gerf's Avatar
Gerf
^^^^^^^ @paulo57509 is right, the upper rear bolt is in a tight spot. No need to disconnect any lines just lean it over.
Old Feb 6, 2025 | 10:58 AM
timmy0tool's Avatar
timmy0tool
ah i type corrected! touched the compressor mounting bolts but did not disconnect the lines.
Old Feb 9, 2025 | 08:35 PM
Superfast1's Avatar
Superfast1
Ok. Thanks guys!
whazzzzuup
Oct 29, 2020 04:05 PM
ivnnln
Jan 23, 2013 03:42 PM
Phillman1
17
Jun 22, 2012 11:11 AM
jtbel
14
Sep 10, 2011 07:49 AM
DrivewayAl
Aug 19, 2011 02:32 PM
