Horn intermittent
Old 03-24-24, 10:05 AM
Redboy
4th Gear
Redboy's Avatar
Default Horn intermittent
When the temperature is warm outside it works when it's cold it's intermittent I don't understand. Fuse is good 10 amp number 19 location. Horns are new. Must be out the steering wheel what do you think.
Old 03-24-24, 11:44 AM
bradland
bradland's Avatar
Clockspring..?
fedaykien (03-24-24)
Old 03-25-24, 10:47 AM
cyfi66
cyfi66's Avatar
The horn is grounded through the steering column - the part that slides. There is also grease between the sliding components which doesn't help with conductivity. I had the same problem and ran a new ground wire from the stationary part of the steering column to the part that telescopes in and out and it solved my horn issues.
timmy0tool (03-27-24)
wordwrkr
12-10-19 02:01 PM
Memo2jz
12-16-16 04:55 PM
CK9887
IS F (2008-2014)
18
10-09-12 10:44 PM
SC300_704
SC- 1st Gen (1992-2000)
11-10-11 04:24 PM
grhopper
10-18-09 04:45 PM
Quick Reply: Horn intermittent
