Front spring - mounting on strut
Old Feb 28, 2024 | 06:55 AM
Troels's Avatar
Troels
Default Front spring - mounting on strut
I have bought OEM struts for my LS400 1995 for a full replacement front + back. As OEM front springs are not available from Lexus I bought the closest match I could find from KYB. Upon assembly, one thing struck me: The rear ones fitted with relatively little compression, but to mount the front ones (431 mm) the amount of compression needed to fit the nut was quite a lot, almost to the point where the spring distorts slightly to one side.
Is this "normal" for the front springs mounted to factory struts on a LS400 (1995) ?
Old Feb 28, 2024 | 07:47 AM
peterls's Avatar
peterls
Are you sure you needed new springs? I have replaced my rear ones (1990 LS) because when trunk was full, it looked too low, but then the new ones looked exactly the same (with a full trunk)! These springs don't go bad, even after 30 years, even rear ones which seem to be softer...
Old Feb 28, 2024 | 08:13 AM
Troels's Avatar
Troels
I had some crappy coilovers so yes unfortunately.
Old Feb 28, 2024 | 08:40 AM
peterls's Avatar
peterls
Sorry to hear that.
Old Feb 28, 2024 | 05:15 PM
timmy0tool's Avatar
timmy0tool
sounds about right since the front has to hold up the engine! how does the car look when all are installed?
i don't think you can make the mistake of installing the rear springs up front and vice versa, since iirc the rears are much larger in diameter.
Sportznuts
Mar 12, 2026 05:47 PM
Felix
Jan 20, 2026 11:48 AM
jvah1980
Aug 19, 2017 07:57 PM
GSa
Apr 20, 2016 05:19 PM
RVamiri
Jun 18, 2012 11:47 AM
