1993 JDM Celsior fuel pump
Hi and good morning to all,
My problem today concerns (as usual) my fuel pump. It was working just fine until I took it out this morning to go to the grocery when it shut down about 100 yards from my garage for, as it turned out, lack of gas. So I went ahead and put a 12v jumper to the FP tap in the engine diagnostic connector and she started right up and took me back home. When I remove the jumper it still won't start.
Do you think that's a prob with the pump itself or could it be the fuel pump control ECU (89570-50010 - in the trunk)?
If the pump runs when jumped directly thru the Diag Connector, the pump works. Cross off a bad fuel pump off your list.
Is the fuel pump not running a intermittent problem? You might want to look at the fuel pump relay? If you have a wiring diagram, you might try jumper the socket terminals that feed the fuel pump (essentially bypassing the relay). I don't know how expensive the relay is, you may just want to go ahead and replace it.
avhart (09-01-23)
Hey Paulo, thanks for the reply. In my case the car does not have a fuel pump relay. It has instead a fuel pump control ECU (89570-50010) so I'm wondering if that is my problem.
paulo57509 (09-01-23)
If you can find a controller, this might be the easiest route.
Hopefully, someone will come along with a fueling wiring diagram or some further diag procedure.
avhart (09-01-23)
First of all, I'd check the voltage of the pin 5 line (G) of the fuel pump ECU (lower left corner). This line should be between 5-8V when fuel pump ECU is driving the pump with lower speed. When the fuel pump ECU is dead or not working right, the voltage is lower than 5V. Sometimes semi-short circuited fuel pump causes too low voltage though.
The following 2 users liked this post by Yamae:
avhart (09-02-23),
Thank you so much for that detailed explanation, Yamae. I will check that voltage later today. On a related matter, what is your opinion if I were to just bypass the module completely and run the pump at 12v continuously.
avhart (09-02-23)
Got it, thanks. I will disregard that option for now. Unfortunately I have the feeling that the pump is once again the problem and not the control module but I will do my due diligence. These pumps keep failing on me continuously...
Could it be possible for a bad control module being the cause for the fuel pump failures.
avhart (09-02-23)
Well not too long ago I opened up the module and saw like a small part of the PCB had a burn so maybe that's really it.
