been having trouble with my 2000 Lexus Ls400 with rough idle, acceleration problems (especially when the A/C is on) jerking in idle and when going in reverse. 1200+ rpm once started. I changed the spark plug in cylinder 4 which made the 304 go to the bottom of the codes listed. Just trying to figure out where I should start
This is where I would start. I'd do a compression test on the engine, all 8 cylinders to make sure you have reasonable compression throughout the engine to make sure you a reasonable good compression, then also I would clear all the codes, then check for trouble codes again. I wouldn't throw a ton of money at an engine that may or may not have a fundemental problem, you won't know until you perform a compression test.
Make sure your timing belt looks okay, I mean if its never been replaced that's a big problem too. So that's where'd I'd start, the most important things, is my engine okay or is there something wrong with it. Because at that point if the engine is bad and you like the car, look at getting a known good engine and just replace it.
It was a new timing belt but I did remove it alot in order to get to the alternator not sure how to check the timing belt
Ill do that. Also should I replace the sparkplugs since I'll be done there anyway
I'm sorry if I'm wrong, but I think that you've mistaken the accessory belt for the timing belt. Please read through the FAQ https://www.clublexus.com/forums/ls-...questions.html
and especially the section on Timing Belt removal and installation. There is a tutorial with pictures that will give you an idea as to what parts are what...
With that mileage, I would take the intake off and clean every passage going into the throttle body. There is an air mix path passage, accessible by removing a cover plate directly on top of the throttle body that gets gunked up with carbon. This is also responsible to how smoothly the transmission shifts and made a difference on my 162k mile car. Should be 8 little holes once the cover plate is removed, make sure they're not plugged.
Non the CEL isn't on but the vsc light is.
Just those 4 codes.
If the VSC light is on, this is where I would start. Your report doesn't show any VSC codes, probably because Autozone's scan tool doesn't read manufacturer specific codes. You'll need to pull the codes thru the underhood DTC1 connector (located on the driver's side of the intake manifold).
Sounds horrible. I would take off the accessory belt and try and spin the idler pulley and tensioner pulleys by hand. I'm hoping that it's those bearings that are bad and not the idler and tensioner bearings inside the timing belt covers that are making that noise. I guess it also could be the bearing on the fan bracket or even the water pump. Try and find out what is making the loud sound. Harbor Freight has mechanic's stethoscopes for a reasonable price...
And did you see a sticker on any of the engine covers that noted the date and mileage that the timing belt was changed? That is of the utmost importance with the '98-00 ls400's as our engines are interference engines, which means that the pistons and valves can damage each other if the timing belt breaks which basically means writing off the engine and either replacing it, or junking the car. Bad place to be and expensive either way.
