Sponsored by: CARiD
problem with LED for DRL
Old Jan 4, 2010 | 09:03 PM
vi3tnam66's Avatar
vi3tnam66
Unhappy problem with LED for DRL
like the title state, i bought a set of JDM White 68-SMD 9005 HB3 LED on ebay, when the bulbs arrived i plug them in, its shock me when i discover that only the first two role are light up, here's the picture. after that i did some research and ran across some posts saying that i need the module from V-leds. i went a head a bought a pair, when i plug the bulbs in the module, only one side is giving full power, the other side still only light the first two role like the picture. i spend my whole afternoon switching the module around but nothing works. did anyone got the same issue and get it resolve? PLEASE HELP
Old Jan 4, 2010 | 09:18 PM
5t341th's Avatar
5t341th
its the leds. they are burnt out
Old Jan 4, 2010 | 09:29 PM
vi3tnam66's Avatar
vi3tnam66
thanks for the reply, i dont think its the bulb because when i turn on my High beam the whole bulb power up
Old Jan 4, 2010 | 09:31 PM
Sash1mi's Avatar
Sash1mi
That's E-YAY for ya!
Old Jan 4, 2010 | 09:34 PM
vipjason's Avatar
vipjason
here check out this link:
https://www.clublexus.com/forums/lig...c-led-dlr.html
Old Jan 4, 2010 | 09:48 PM
1SWTGS's Avatar
1SWTGS
just run a switch to the battery.I try the v-led module.but it aint so bright I think its just running 1/2 power to the bulbs like the oem dlr.
Old Jan 4, 2010 | 09:53 PM
vi3tnam66's Avatar
vi3tnam66
can you show me the steps and what do i need to buy, thanks
Old Jan 4, 2010 | 09:56 PM
bigguppy's Avatar
bigguppy
I dont have a fix for this but only an oppion that some bulbs on our car that required module to work properly should not be change. Example DRL bulbs and tail light. If your unlucky you get electrical damges. This is from my experience with LED tail. Cost for fix would be $1,000 or more if it was'nt for my warranty. Bulbs that I see being ok are 73, and 194.
-Just my opion- Hope you find a fix soon.
Old Jan 4, 2010 | 10:00 PM
istundra's Avatar
istundra
Just run a relay from battery triggered by your existing high beam wire and have it output to a new 9005 harness to your LED bulbs.
The DRL will trigger the relay; thus releasing the full power to your LED bulbs.
A fog lamp harness can fix this problem along with other small parts. You just need to wire it correctly.
Old Jan 4, 2010 | 10:09 PM
1SWTGS's Avatar
1SWTGS
Old Jan 4, 2010 | 10:10 PM
1SWTGS's Avatar
1SWTGS
hope this helps~~>http://www.accessconnect.com/fog_dri...hts_wiring.htm
Old Jan 5, 2010 | 01:33 PM
skiz88's Avatar
skiz88
Couldn't he just use a PIAA 9005 bulb instead and just plug n play? Wouldnt this work as both high beam and DRL?
http://www.racinglab.com/pixtremwhitp1.html
Old Jan 5, 2010 | 07:49 PM
istundra's Avatar
istundra
This is exactly what you need to do.... except running a manual switch from inside the cabin, use your existing 9005 output as the trigger. This will work as a switch.
Now that the harness is working, output it to the two 9005 LED bulbs.
No need to run any extra switches and such to the cabin.
Old Mar 6, 2010 | 03:48 PM
vi3tnam66's Avatar
vi3tnam66
thanks for all your help but finally got it to works. here's the pix and the resistor that i used to make it work. no v-leds module needed.
http://www.v-leds.com/Exterior-LED/D...01806-1-3.html
Old Mar 24, 2010 | 11:19 PM
dair805's Avatar
dair805
Nam66, Does your light flicker?
