Sponsored by: CARiD
HIDEXTRA.com HID Review
Old Feb 15, 2010 | 04:47 PM
  #286
lexforlife's Avatar
lexforlife
i need to order a set of h3 6k for 97 sc300
does your plug mate to oem power plug for lexus sc 300 on my last set i had to hack off the plugs and hard wire for fogs
does anyone have a picture of actual plug from this kit for h3 kit so i can see if same is required on this kit
Old Feb 16, 2010 | 04:06 PM
  #287
HIDXTRA's Avatar
HIDXTRA
Former Sponsor
HI,
our kit is direct plug and play with either male/female plug or wire harness that has metal prong that can be plugged in directly into your oem connector. Thanks~
michelle
Old Feb 17, 2010 | 04:34 AM
  #288
lexforlife's Avatar
lexforlife
Originally Posted by HIDXTRA
HI,
michelle
can you post a quick pic of the actual connector which is the power source
i still have the oem connector plug that i chopped off to hard prior kit , i can reattach it but before i do this i wanna make sure it will mate to your connector
the oem connector plugged into the back of the oem fog housing .. with hid you dont use that sorce anymore for the wires come thru the back of the housing to connect to hid connectors so exactly how doe that same plug mate to yours
Old Feb 17, 2010 | 12:17 PM
  #289
HIDXTRA's Avatar
HIDXTRA
Former Sponsor
HI,
We do apologize but we don't have pictures of our parts since some wire harnesses from one kit to another looks differently. Thanks~
michelle
Old Feb 17, 2010 | 04:03 PM
  #290
rselby's Avatar
rselby
all the kits are plug n play( correct)...I just orderd a 6000k kit for my fogs...will this require me to run power wires from the battery to the ballast?...
Old Feb 18, 2010 | 01:58 PM
  #291
HIDXTRA's Avatar
HIDXTRA
Former Sponsor
Relay not needed for fogs, thanks~
michelle
Old Feb 19, 2010 | 12:06 PM
  #292
albis350's Avatar
albis350
Thumbs up
Just ordered a set of low beans 6k couldn't resist the awesome price and the great reviews
Old Feb 26, 2010 | 12:56 AM
  #293
cino21's Avatar
cino21
just ordered 10k lowbeams
Old Feb 26, 2010 | 02:51 PM
  #294
Maliy0204's Avatar
Maliy0204
I want to order 6000k hids for my Lexus gs400 year 2000. Which one exactly do I need? Thanks
Old Mar 1, 2010 | 03:36 AM
  #295
potatoBBQ's Avatar
potatoBBQ
I think I have the same question as lexforlife... Do the positive/negative wires coming from your HID H3 bulb plug into the factory leads on the circular black housing cover and then the wires on the ballast plug into the other side of that circular black housing cover (like the factory halogens)? Or would your HID H3 bulb plug directly into the ballast and then we would have to cut/drill into the factory circular black housing cover? Attached are a couple of picture of the 97+ SC foglight housing (from neurocity's DIY):
Attached Thumbnails HIDEXTRA.com HID Review-298.jpg   HIDEXTRA.com HID Review-dscn3589.jpg
Old Mar 1, 2010 | 11:15 AM
  #296
whise's Avatar
whise
michelle
what about for headlights 9006 HID Conversion lit
Old Mar 1, 2010 | 11:32 AM
  #297
tpham86's Avatar
tpham86
you have to cut a hole in the factory housing. A total of 4 wires will need to fit through it. I just cut the wires coming off the h3 bulb and soldered them back together after running it through the hole.
Old Mar 1, 2010 | 02:13 PM
  #298
hoonami's Avatar
hoonami
what is warranty on these hid kits?
Old Mar 1, 2010 | 05:01 PM
  #299
HIDXTRA's Avatar
HIDXTRA
Former Sponsor
Hi,
Does your car come with stock HID or stock halogen? Since you didn't specify see below for ordering instructions
Ordering Instructions:
1.) Go to this link to check on bulb type
http://www.sylvania.com/ConsumerProd...lacementGuide/
2.) Then go to www.hidextra.com and choose the (BULB TYPE AND COLOR)
3.) Use Express checkout
4.) Input coupon code: springsp-m to get $17 off the kit price
Input coupon code: tenpercentoff-m to get 10% off bulbs only, ballast or accessories
5.) IF you are purchasing more than one kit, please do SEPARATE transactions for EACH kit in order to get discount on all kits.
Thanks~
Michelle
Old Mar 1, 2010 | 05:03 PM
  #300
HIDXTRA's Avatar
HIDXTRA
Former Sponsor
HI,
In your case, the prongs come from wire harness.
so
bulbs --> ballast --> Wire harness --> Oem connector
And you would need to drill a hole in your housing cover or not use the cover at all. thanks~
Michelle
