Sponsored by: CARiD
HID cut off not straight
Old Feb 17, 2009 | 06:45 PM
GS4_Fiend's Avatar
GS4_Fiend
Originally Posted by GS300Rich
somehow this is backwards, is it because the GS headlights are reflective housing? DO you have a pic of the kit?
Yeah, they use reflectors. That is why they use D2R bulbs. My cut off is not 180 degrees straight like the LS430. I think it is because they use projectors with D2S.
Old Feb 18, 2009 | 11:58 AM
bigcory's Avatar
bigcory
I think it is bulb related. Try switching the bulbs from side to side. I recently replaced my bulbs with 6000k's. Drivers side has a noticable "hotspot" of light, the beam is no longer straight, and it now slants down as it moves away from the center of the car.
Old Feb 25, 2009 | 11:35 PM
GS4_Fiend's Avatar
GS4_Fiend
Can the reflector housing type have straight cut offs?
Old Feb 27, 2009 | 06:24 PM
cduluk's Avatar
cduluk
it looks like the cutoff shield is bent, either that or the headlight itself is tilted.
Old Feb 27, 2009 | 07:05 PM
GS4_Fiend's Avatar
GS4_Fiend
How do you find out? How do you fix it?
Old Feb 27, 2009 | 09:06 PM
cduluk's Avatar
cduluk
can you take better pictures?
I'd need a few pictures of the car maybe 25ft from a wall. Take a pic with both lights on, then one with only left, then one with only right.
That way i can better diagnose the issue. I know a LOT about projectors- i just need better pics and i'll know exactly what's wrong with yours.
And you said 07-present ES350? that cutoff does NOT look like it's from an oem 07-09 Es350.
Old Mar 2, 2009 | 12:20 AM
swifty562's Avatar
swifty562
so when you had regular halogen bulbs did it do the same thing? if so then the light must be adjusted.
also, with halogen bulbs did u get two cut lines with it? if yes, then you must of place your passenger side hid bulbs incorrectly to get this bad of a light.
where your bulb sits in a housing no matter in a reflective bowl or projector, if place incorrect, the output can be devestating.
Old Mar 2, 2009 | 10:02 AM
cduluk's Avatar
cduluk
huh?? I thought he had an Es350? You need to provide correct information.
Old Mar 2, 2009 | 10:42 AM
swifty562's Avatar
swifty562
what do u mean?
Old Mar 3, 2009 | 12:15 AM
GS4_Fiend's Avatar
GS4_Fiend
Gs430...........
Old Mar 3, 2009 | 10:16 AM
cduluk's Avatar
cduluk
what year gs430? The 01-05 or 06-07?
01-05 used reflector type headlights while the next gen used projectors.
Where's the OP
Old Mar 3, 2009 | 06:42 PM
cliffud's Avatar
cliffud
Former Vendor
looks like the bulb is in wrong.
Old Mar 4, 2009 | 02:06 PM
ewu888's Avatar
ewu888
hey cduluk thanks for the reply. I have an 08 es350 and it came stock with halogens. I'll post pics of my car asap so you can take a look at them.
Old Mar 4, 2009 | 05:56 PM
cduluk's Avatar
cduluk
the ES350 has an option for halogens??? I thought they were all HID.
In that case, you cannot just stick in an HID kit into the halogen (projectors?). Halogen projectors and HID projectors are totally different by the way they reflect light.
Something still seems fishy here...
GQis350
Jul 31, 2012 10:12 AM
ArmyofOne
Jun 9, 2011 09:04 AM
talucci
Lighting
Jul 29, 2009 05:59 PM
ba-b4
Nov 30, 2007 06:12 PM
shikbas
Lighting
Oct 21, 2005 05:30 AM
