Sponsored by: CARiD
70 Watt Ballasts - Anyone using them??
Old Feb 7, 2008 | 10:51 PM
shftup's Avatar
shftup
Question 70 Watt Ballasts - Anyone using them??
Any CL'ers using 50 (i meant 50, not 70 watt) Watt ballasts with their headlights.
If so, can you post a couple of pics. Also, can any harm be done using a 70 watt ballast, other than lower the life of you HID bulbs.
S
Old Feb 8, 2008 | 01:48 AM
lilboi's Avatar
lilboi
There are specific bulbs to work with high output ballasts. They're a bit more then your regular d2s bulbs, but they are made for those supercharged ballasts. Keep in mind that when you supercharge a ballast, the bulb will give a yellowish hue to the output.
Old Feb 8, 2008 | 07:46 AM
DarKnight's Avatar
DarKnight
I'm running some 50w ballasts. Sorry I don't have any output pix (I lost the cable to transfer pix from my cam to comp). I will try to take some with someone else's cam. The output is great. It's not a huge difference but you definitely have more light output, you can see the road signs light up for what seems like a quarter mile.
Contact JeffTsai, I think he has or is working on some 70w ballasts. But as the other poster mentioned you will need bulbs made specifically for your application because the output will be yellow and dimmer. I ran some 35w bulbs for a couple weeks and had to switch over to 50w bulbs because it seemed as though my bulbs were dying.
Old Feb 8, 2008 | 07:58 AM
shftup's Avatar
shftup
Did you do a ballast mod to get the extra watts, or did you buy an aftermarket ballast (if so, from where). Plus where do you buy the DL 50?
Thanks
Old Feb 8, 2008 | 03:05 PM
DarKnight's Avatar
DarKnight
I bought the 50w ballasts from Cliffud (a member on this board). I bought the bulbs on eBay.
Heng350
Lighting
Apr 28, 2009 10:19 PM
gsCrazy
Lighting
Feb 1, 2007 01:24 AM
garbage85
Lighting
Feb 10, 2006 05:59 AM
dgangi
Jun 4, 2001 02:04 PM
