Sponsored by: CARiD
LS400 HID Part Identification...
Old Jan 18, 2008 | 01:06 AM
Jasbmo's Avatar
Jasbmo
Default LS400 HID Part Identification...
10 characters
Old Jan 18, 2008 | 03:06 AM
lilboi's Avatar
lilboi
1: That's the ballast.
2: That's the power wire that connects to the ballast.
3: Autoleveling motor.
4: Looks like a breather tube.
5: d2r/d2s bulb plug. Comes from the ballast and connects to the bulb.
6: The autoleveling motor does all the moving. All other parts pivot. From the looks of the housing, it looks like both high beams and low beams move together.
Old Jan 18, 2008 | 10:01 AM
greyBLITZ's Avatar
greyBLITZ
Also, it is most likely a D2R bulb since I'm almost completely certain that your headlights are the reflector type.
Old Jan 18, 2008 | 01:08 PM
Caoboy's Avatar
Caoboy
park on a road, turn car off, turn it on. then go park in a driveway, turn car off, turn car on. see if it adjusts?
Old Jan 18, 2008 | 04:15 PM
lilboi's Avatar
lilboi
Originally Posted by Jasbmo
What is the best way to test if your auto leveling works?
Install the headlights and turn your car on. When the car is switched to the on position the headlights will swing down, then up. That way you know your levelers are working.
Old Jan 18, 2008 | 06:31 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
check the wiring at the 2 wheel height sensors (front pass. and rear drivers iirc, might be reversed ) and make sure that nothing's loose.
Old Jan 18, 2008 | 11:40 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
you would get a warning message on the dash if anything was wrong with your auto leveling.
If you wanan double check, turn your lights on and start the car. Should swing down, then back up.
Yes, on the LS, both low's and high's adjust.
Old Jan 19, 2008 | 10:28 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
What does the error message say on the dashboard?
My headlights go down, but on the way back up, they hesitate slightly.
This is still the issue even with the new HIDs
It will say somethign along the lines of "autoleveling failure" or something of that nature.
Seems like you might need to tighten up the sensors behind the wheels.
Old Jan 20, 2008 | 07:00 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Originally Posted by VIPtoyz
Sorry I know this is a little off topic but would you be able to take all that part out from the HID headlight and put it into a regular headlight. My headlight is in bad shape right now and I try to get a new pair to repalce it but the price for a brand new set is too much. Can I just take all that parts out and swap it over to an Non HID one?
I would just get one of those headlight cleaning kits, and it will look brand new.
Basically you sand it down, and polish it.
Old Jan 20, 2008 | 09:07 PM
PureDrifter
BahHumBug
CL Folding 100,000
to answer ur question, No, you can't.
iirc Depo makes a replacement headlight for NON-HID 98-00 cars.
Botto
Jun 23, 2018 07:09 AM
TheAzn
Lighting
Dec 21, 2013 06:34 AM
4TehNguyen
Sep 3, 2013 08:34 AM
fstpassat
IS F (2008-2014)
Nov 29, 2012 08:46 AM
nguyen430
May 22, 2009 12:46 AM
