Sponsored by: CARiD
mobilehid vs xenondepot
Old Oct 20, 2007 | 10:49 AM
turbo1's Avatar
turbo1
Default mobilehid vs xenondepot
I bought mobilehid's for my rx300. They look good but not perfect. When I look at them on the garage doors they are a off on the edges. How are xenondepot's vs these? Can I just switch to xenondepot's bulbs in the mobilehid's housing or would I have to buy the whole kit if I wanted to switch and what would be the benefits/negatives of doing this.
Old Oct 20, 2007 | 11:05 AM
mikal's Avatar
mikal
Your beam pattern will be the same
Old Oct 26, 2007 | 04:28 PM
DarKnight's Avatar
DarKnight
Yup. The only way you will get a nice cutoff is if you have HID housings or do a retrofit. Remember that the halogen housing was made for halogen bulbs so they will not reflect the light from an HID bulb properly.
Old Oct 27, 2007 | 02:51 AM
tcheung87's Avatar
tcheung87
The responses you got were correct. The beam pattern is described mostly by our RX300's reflector housing, and since you and I have OEM Halogen capsule housings we get an awkward cutoff. It's not too bad for me I've never had any problems and I've seen my lights from other cars and it's not bad.
The only way to change the cutoff is to do a retrofit with HID projectors, or doing the OEM RX HID swap.
Old Oct 27, 2007 | 09:44 AM
turbo1's Avatar
turbo1
So if I want to keep the black headlight housing on the 99 rx300 (because I don't like the chrome headlight look) I would just need to change to the hid reflector housing?
Old Oct 27, 2007 | 10:02 AM
iSuxeL's Avatar
iSuxeL
You got it!
Old Jan 18, 2008 | 12:20 PM
turbo1's Avatar
turbo1
Where would I get just the housing?
Is it easy to replace?
Then would there be a difference between the two hid's, mobilehid vs xenondepot?
Old Jan 19, 2008 | 12:36 AM
dimsumboy's Avatar
dimsumboy
for those kits, you just straight replace the bulb without any mods? I'm interested in getting one
Old Feb 18, 2008 | 12:40 AM
cliffud's Avatar
cliffud
Former Vendor
dimsumboy- here are the steps.
1) remove halogen bulbs
2) insert HID bulbs
3) install wire harness to all the necessary connections: + and - terminals on the battery, left and right ballasts, and OEM headlight plug. Here is a pic of the wire harness that is included in the mobilehid kit.
4) turn on lights and smile.
Here are some youtube videos of an RX300 owner with the mobilehid kit installed.
http://youtube.com/watch?v=KenKkU7rDGQ
http://youtube.com/watch?v=8moyzL5l4Aw
Enjoy.
c.
Sc0pe
Lighting
Apr 19, 2014 12:16 PM
SaiyanGS3
Lighting
Oct 24, 2011 03:19 PM
2JZSteven
Lighting
Jul 2, 2010 08:34 PM
jhong28
Mar 31, 2007 06:38 PM
1.5RS-T
Lighting
Jun 14, 2003 12:28 PM
