Sponsored by: CARiD
HID Problem
Old Jul 13, 2007 | 10:23 AM
gapxguy's Avatar
gapxguy
Default HID Problem
Every time I turn on my headlights, both headlights turn on. About 30 seconds to a minute, the driver side headlight shuts off. I can turn it off and on again and the same thing will happen.
This is a 98' GS400 with factory HID w/6000k bulbs. Is it a faulty ballast? TIA.
Old Jul 13, 2007 | 10:30 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
I would suggest swapping the components left to right. This will enable you to determine whether its a faulty bulb or ballast.
steve
Old Jul 13, 2007 | 10:33 AM
cliffud's Avatar
cliffud
Former Vendor
gapxguy- my xenondepot kit did the same thing. turns out the spade connector within the turn on plug wasn't seated properly so I had to modify it.
Old Jul 13, 2007 | 01:54 PM
1sweetGS's Avatar
1sweetGS
It sounds like it might be a faulty ballast and you will need to purchase another one. Sometimes with HIDS though it's hard to tell! I also have a saab 93 with HIDS and I was having the same exact issue. Everyone said it was a bad ballast, but what it turned out to be was really cheap bulbs..I returned my bulbs 2 times with the company I bought from and then decided to purchase from somewhere else and I haven't had a problem since.
Old Jul 16, 2007 | 12:27 AM
gapxguy's Avatar
gapxguy
As much I would hope this would be the problem, I doubt it is since it turns on every time and shuts off at the same time interval consistently.
Swapping components from left to right is a great idea, thanks for the advice.
Old Jul 16, 2007 | 09:59 AM
Caoboy's Avatar
Caoboy
just start with swapping the bulbs. if it still happens on the same side, its the ballast. if i happens on the other side, it's the bulbs.
Old Jul 19, 2007 | 11:26 PM
vwynn's Avatar
vwynn
maybe its a safety thing? because something wasnt plug in correctly? iono... hope u get it fixed
Old Jul 20, 2007 | 05:24 AM
URDONE's Avatar
URDONE
Let us know what you find out.
Old Jul 20, 2007 | 08:20 PM
gapxguy's Avatar
gapxguy
Alright, I swapped in a different bulb and turns out the existing one was bad. Right when I took it out, I knew it was the bulb since the glass was cloudy.
I put in a new 6000k bulb and it's a night and day difference in color. The new 6000k bulb looks like 4300k after warming up compared to the other side which is almost 3 years old.
Looks like I'll be shopping for a matching set of bulbs now. On a better note, at least it wasn't the ballast.
4TehNguyen
Sep 3, 2013 08:34 AM
Willdb15
Lighting
Jun 9, 2010 12:11 PM
SlickNick3
Jun 1, 2010 06:45 PM
AKIS350
Jul 25, 2009 03:52 PM
GS408
Lighting
Sep 1, 2004 12:51 PM
