Sponsored by: CARiD
1997 Hid Headlamps
Old Jan 14, 2007 | 01:06 PM
rfong's Avatar
rfong
Default 1997 Hid Headlamps
I have a 1997 ES300 and was wondering if there is a diiference between the headlamps that came with factory HID's compared to the headlamps that came without factory HID's. If they are the same part how would I go about upgrading to the factory HID system.
Old Jan 14, 2007 | 02:10 PM
LXMN's Avatar
LXMN
The 00-01 came with optional HID headlamps. The reflector housing is different than those that are halogen. They are made to accomodate D2R bulbs. They will fit your 97 with no problem as the mounting bolts are the same. Check out the ES300 forum or do a search for more info.
Old Jan 15, 2007 | 04:48 PM
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
SO the 01+ headlights are a direct fit to a 97 ES?
Old Jan 15, 2007 | 05:37 PM
LXMN's Avatar
LXMN
Only the 00-01 headlights that are HID are a direct fit for the 97.
I think that is what I said. RIGHT?
Old Jan 15, 2007 | 06:24 PM
tmf2004's Avatar
tmf2004
Is there any additional wiring or cutting that needs to be done to accommodate the newer lights or is it a direct swap.. Just bolt and go? thanks
Tony
Old Jan 15, 2007 | 06:49 PM
chrispy's Avatar
chrispy
Tony
actually i heard you have to cut part of the radiator harness or something. not sure what it was but i'm sure you could find out by searching.
Old Jan 15, 2007 | 07:59 PM
vin 78's Avatar
vin 78
To mount the `01 housing to a non-HID ES (97-01) you will have to CUT some parts of the metal radiator support. You will have to cut two parts one above and one below the housing - one section is about 2"x.75" and the other is long, about 3.5"x1"
When I bought mine, I had no idea that you have to modify it. Its probably because of the ballasts thats mounted under the housing.
Old Jan 18, 2007 | 06:26 PM
tmf2004's Avatar
tmf2004
It sounds like only the radiator needs modifying.. What about any wires? Do all the plugs match up correctly to the lights?
Old Jan 20, 2007 | 07:03 PM
shahir18's Avatar
shahir18
the harness are diffrent... i just cut my factory harness and direct wired the headlamps
Old Jan 21, 2007 | 08:15 PM
charley240's Avatar
charley240
there needs to be small slices cut into the radiator support. it does not take much work really. just a simple hacksaw will do the job. not much work required at all really. just a matter of where to find the oem hid setup is the problem.
Goodluck
Charley
gulffishin
23
Dec 31, 2007 01:36 PM
Andoskyy
Feb 25, 2007 09:28 AM
SEXY LEXY
Lighting
Oct 9, 2005 04:53 PM
Rockero28
Lighting
36
Feb 10, 2005 10:08 PM
