Fix Faded Headlights
My ES suffers from faded headlight covers where the sun has made them go a horrible cloudy color.
I decided maybe i should get another set of headlights until I saw the post in the SC forum and spotted a topic on how to clean your headlights.
I would like to post my tip on how to clean up your headlights and have them immaculate.
All i used was a rubbing compound otherwise known in the UK as T-Cut. Basically it is a rubbing compound used for paintwork which takes a very fine layer of paint and on headlights it works a treat! Also if your center interior console is scratched this also works a treat! Brings that plastic wood up beautiful.
My lights now look brand new! And those projector lights look awesome when thing are clear!
thank goodness for T-Cut!
steve
Try doing a tester on the very top first... I did... when i could see the difference i did the whole light..
it has made me very happy as the lights really spoilt the car because of the faded lights.
now new.. just wish i had taken a before photo shot and after so i could post it.
Tire shine i use on my Fenders and skirts... brings it up very nicely...
steve
Not quite sure if you call it rubbing compound in the U.S but if you explain its for taking a fine layer off the paintwork then should know what it is called.
Another thing i used this for is when my local Lexus garage backed into another car and put a mark on my fender. They used a rubbing compound for a few minutes and it was gone.. no trace of the scratch at all.
But like i said earlier.. make sure you do a test on the very top of the light in case it is a bit harsher then my compound.
