Sanding Headlights
Old Jan 6, 2005 | 11:38 AM
rpx13's Avatar
rpx13
Default Sanding Headlights
I've done a search on sanding down the oem headlight, but does anyone know where I can see before and after pics? thanks guys!
Old Jan 6, 2005 | 12:22 PM
lexusk8's Avatar
lexusk8
I hope you don't literally mean using some kind of grit paper like 2000 grit to sand your headlights That'd be the last thing I think of if my headlights were to become hazy or oxidized, as fine spider-web scratches would appear on the headlights surface.
Instead, you might want to look into using more effective and preferred solution methods like a plastic polish or cleaner, Meguiar's PlastX or Scratch-X, or as a last resort, rubbing compound.
Old Jan 6, 2005 | 01:38 PM
ebruce2's Avatar
ebruce2
on the contrary, wet-sanding is very effective when done properly. I have some pics somewhere that explain all the steps. It was done by an SC owner on here i believe. Give me some time and I will post them for you.
Old Jan 6, 2005 | 01:43 PM
ebruce2's Avatar
ebruce2
try this for starters
Old Jan 6, 2005 | 01:44 PM
ebruce2's Avatar
ebruce2
2 of 4 .................
ebruce2's Avatar
ebruce2
3 of 4 ..............
Old Jan 6, 2005 | 01:46 PM
ebruce2's Avatar
ebruce2
and finally .......
Old Jan 6, 2005 | 01:58 PM
rpx13's Avatar
rpx13
thanks ebruce2...thats exactly what I was looking for....I heard starting out with a 600 or 800 is better before eventually moving up to a 1500 grit....I'll give it a try and see what happens....again, thanks!!!
Old Jan 6, 2005 | 06:56 PM
gapxguy's Avatar
gapxguy
Wow, very nice. Where can I find 3M sqirl mark remover?
Old Jan 6, 2005 | 07:15 PM
ebruce2's Avatar
ebruce2
Exclamation whoa.....easy there, killer!!
no, no, no!!!!!! You definitely don't want to start out that rough!!!! I guarantee that with a 600 or 800 you will go far enough into the plastic that you won't be able to get them clear again. PLEASE do yourself a favor and use a 2000 grit ONLY. That's what I used for the wet-sand step, followed immediately by the Swirl Mark Remover, then a few layers of Novus Plastic Polish (any brand will do)
I got the 3M stuff right off the shelf at Pep Boys...should be easy to find. Good luck!
Old Jan 6, 2005 | 07:21 PM
LB Lex's Avatar
LB Lex
1500 grit should the the heaviest grit you use, but I would stay with 2000 if this is your first time doing this because it will take less work to remove the fine scratches. Wetsanding is pretty much for severly scratched/pitted lights. What's the condition of yours? You might only need to polish it with a plastic polish. If you don't need to wetsand it you'll save time, effort, and you won't risk damaging your lights if you mess up.
Old Jan 6, 2005 | 08:48 PM
rpx13's Avatar
rpx13
good thing I asked....thanks again guys!!!
Old Jan 6, 2005 | 09:16 PM
ebruce2's Avatar
ebruce2
no problem. Now hold up your end of the bargain and post up some before and after pics!!
Old Jan 6, 2005 | 09:43 PM
rominl's Avatar
rominl
exclusive matchup
yup, ebruce2 covered everything. just start out with the polish stuff and it's good enough. at most just start with rough rubbing compund that's that's good enough
if you start with rough sand paper like 800, you will have a very tough time making it smooth later, very tiring
Old Jan 7, 2005 | 09:08 AM
chuckb's Avatar
chuckb
Does regular Meguiars scratchX for paint work on headlights too?
