Sponsored by: CARiD
HID headlight cutting out
Old May 5, 2006 | 03:38 PM
LexT's Avatar
LexT
Default HID headlight cutting out
driver side headlight turns on, auto levels fine and then turns off, checked connections all fine. Anyone else had this issue? Thanks in advance.
Old May 5, 2006 | 04:08 PM
smello12's Avatar
smello12
I would swap it to the other side and see if it goes out on that side...if so its the bulb...if not it may be a loose wire..
Old May 5, 2006 | 04:29 PM
vicestan's Avatar
vicestan
How do your bulbs look? could be the bulbs are old and the voltage is getting to high for the ballast to support. Check the ground connections. Also since the power is central going to both of the headlights ot definatly not the relay or anything before it.
Old May 5, 2006 | 05:48 PM
Kharizma's Avatar
Kharizma
mine did that and eventually wouldn't turn on at all, had to get it replaced.. unforunately for me i didn't know of phillips so i had to buy OEM which doesn't even match my other O***s so i'm pissed but what you gonna do you know..? good luck
Old May 6, 2006 | 10:08 AM
PHML's Avatar
PHML
Master Thread Closer!!
check the contacts of the bulb...make sure its set in properly. As others have suggested....swap with the other side to see if it does the same thing on the driver-side....if it does...you know its NOT the bulb....and probably the ballast or wires between the bulb and ballast.
Good luck.
Pete
Old May 8, 2006 | 06:14 PM
LexT's Avatar
LexT
Thanks a lot guys for all the input, used a loaner 4000K bulb today, and found out my 8000K bulb was bad. What is a reliable source for some Hid bulbs? - these previous only last me 1 year,
Old May 9, 2006 | 12:57 AM
PHML's Avatar
PHML
go to xenondepot.com....they are a CL vendor.
Old May 10, 2006 | 10:36 PM
side's Avatar
side
try fleabay the 2DR bulbs are about $100 a pair I bought a set of 2DS (projector type) for $75 both 4100k osram.
GSbearcat
Apr 6, 2018 12:51 PM
caramoe
Jul 23, 2017 03:24 PM
jiimpman23
May 23, 2013 09:51 PM
blue99GS4
May 1, 2013 06:35 PM
MIGS
Jun 10, 2011 09:14 AM
