Headlight Ground Wires
Old Apr 2, 2018 | 09:17 AM
GSbearcat's Avatar
GSbearcat
Default Headlight Ground Wires
My passenger headlight is dim, all others are fine. Most research seems to point to an electrical issue. One post from years ago mentions replacing ground wires but didn't give any specifics. Does anyone know the location of the headlight ground wires? Thanks.
Old Apr 2, 2018 | 09:27 AM
captainva's Avatar
captainva
Are they HID or Halogen?
Old Apr 2, 2018 | 09:29 AM
GSbearcat's Avatar
GSbearcat
They are HID
Old Apr 2, 2018 | 10:46 AM
captainva's Avatar
captainva
If they're HID its extremely unlikely that a new ground will make a difference. I would start with replacing the bulbs as the bulbs get dimmer as they get more hours of use. Same goes for the ballasts but to a lesser degree
Old Apr 2, 2018 | 10:48 AM
GSbearcat's Avatar
GSbearcat
Thanks - I'll probably take the driver side bulb and put it in the passenger side to see what happens. If it's fine then obviously a bulb issue.
Appreciate the response.
Old Apr 4, 2018 | 12:21 PM
XenonDepot's Avatar
XenonDepot
Former Sponsor
Swapping your bulbs around is always the best way to rule something out - either you need some new D2R HID Bulbs (do yourself a favour - if you're going to replace one, just replace the pair so they best match each other), or you have something on that particular side causing the issue (whether it is related to general wiring/grounds or a D2R HID Ballast problem is next to determine).
~Robert
Old Apr 5, 2018 | 05:25 AM
newgsman's Avatar
newgsman
Originally Posted by XenonDepot
Swapping your bulbs around is always the best way to rule something out - either you need some new D4S HID Bulbs (do yourself a favour - if you're going to replace one, just replace the pair so they best match each other), or you have something on that particular side causing the issue (whether it is related to general wiring/grounds or a D4S HID Ballast problem is next to determine).
~Robert
I thought the D2R bulbs are the proper ones for these cars..
Old Apr 5, 2018 | 06:04 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
Right you are - I had D4S on the brain yesterday. Fixed my notes above, for the sake of posterity.
~Robert
Old Apr 6, 2018 | 07:35 AM
sakataj's Avatar
sakataj
~Robert
i dont know why for years i thought we used D2S bulbs. i bought an expensive pair of Phillips a year r so ago that are D2S, the base is different on these and i cant use them can i?
Old Apr 6, 2018 | 08:02 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
Unfortunately, D2S and D2R bulbs are not interchangeable.
Danny
Old Apr 6, 2018 | 12:25 PM
sakataj's Avatar
sakataj
Danny
DOH. I dont know how i bought these, but i did
Old Apr 6, 2018 | 12:51 PM
captainva's Avatar
captainva
If you ever do a projector retrofit those are the bulbs you'll want so maybe you can still use them in the future
motorhead
CT 200h Model (2011-2017)
Nov 19, 2015 09:17 PM
jet350
Jan 3, 2011 11:50 AM
TPSTulane
Jan 30, 2009 09:42 PM
biskander
Jan 6, 2008 09:11 PM
LexT
Lighting
May 10, 2006 10:36 PM
