Recently I noticed that the DRLs were starting to look really sad/tired and the illumination achieved on high was not what I was used to.
I pulled the two 9005 PIAA Xtreme White bulds that have been in there for 2 years now. The DRLs are on all the time and I use alot of back roads and country roads so my highs get a fair amount of playing time.
I guess I got my moneys worth on these bulbs.
Here is what I found. They are not blown, they are just all sooty inside and kinda look pregnant.
They have been replaced with Sylvania Silverstars. Lets see how long they go for at half the price.
That soot is basically the tungsten deposit from the filament. The deposit gets really hot and the glass starts to melt and bubble. Once bulbs get that way, toss 'em since they will soon burst. There is nothing more annoying that cleaning shards of glass from inside the headlight housing.
But why would they get this way only after 2 years? Aren't these supposed to be high quality lights? Isn't that why we are paying almost 4 times as much for?
Originally posted by Canyonero But why would they get this way only after 2 years? Aren't these supposed to be high quality lights? Isn't that why we are paying almost 4 times as much for?
high quality that's one thing. higher wattage that's what causes the problem i think
I guess the price you pay for brighter, whiter light output. The silverstars are actually advertised as having a shorter life span. It's in the fine print on the packaging. Don't get me wrong, I think they are high quality, as this is the proper way to get brighter, whiter light output as opposed to slapping 80W bulbs that will melt the harness and wires. You can always spend a couple hundred $$ more and go HIDs.
Originally posted by rominl high quality that's one thing. higher wattage that's what causes the problem i think
these are 55w bulbs, same as the stock ones. I am guessing the soot is from the DRL's constantly being on generating a slow burn. The stock bulbs that had been in for several months before these has the beginings of some buld up but is was white and not black.
Originally posted by T0ked You can always spend a couple hundred $$ more and go HIDs.
why would you attempt to put HID on your high beams? HID are not meant to be constantly turned off and on as the highs would be in oncoming traffic. On this model, the DRLs are the high beam bulbs at 50%. I don't think you could accomplish that effectively and efficiently with an HID setup.
Agreed, HIDs wouldn't work for DRLs. Just an example on how to get brighter lights. Although MB is using HIDs as high beams. A reflective shield closes over the bulb to simulate the high beam flash. But the highs are 65W (9005) and its not the wattage causing the deposition. I've had regular 9005 bulbs which last a lot longer then the Silverstars. I just think that to get the whiter, brighter light, the inert gas and materials used are more susceptible to deposition. That black soot is actually metallic on the other side and is metal depositing on the inner glass surface. That metal gets much hotter and causes the glass to soften and bulge. Anyway, expect the same result with the Silverstars.
