New battery reset??
I am going to replace my battery... I know that I will need to reprogram my stereo, but will it effect or mess up anything regarding my turbo's Apexi boost and fuel guage settings? Will disconnecting the battery have any other effects?
I suggest you look in your aftermarket electronics manuals and see if the memory is reseted if you disconnect power. In any case you should have all your settings written sown so you can tune it all up to the original condition from the scratch. Otherwise there should not be any problems, I disconnect my battery almost every day on my car.
Actually. . . . . thats not a bad idea! seriously. . can it be done? i mean come home for the day, switch off the Battery or the fuse or whatever and leave it for the night. . . the next morning switch it on when you leave for work. . and BAM!
To readjust your ECU?
Haha...I want my transmission ECU to be fresh and rested over night so it could learn some of my agressive driving all over again...yeaH boiiii!
Anyway, while I work on audio the rule #1 is ALWAYS to disconnect the battery before doing the wiring.
so let me get this straight retrodrive . . . you actually pop the hood and disconnect your battery everyday? haha i don't know thats just amazing to me. . . I do it probably once a week at the most but everyday? dayam. . . .
Well, I work on my system every day when the car is not in the shop.
McNelson, write everything down and go for it. Better yet call up the shop that installed the toys for you. they should answer these kinds of questions.
I made a bunch of calls and the Apexi controllers hodl their memory if the battery is disconnected. But now I have to spend forever to reprogram my entire system (well the eq anyway for the most part)
You can also use a quick switch battery disconnect such as this.
http://www.racerpartswholesale.com/rebco5.htm
TLPLEXUS
HS 250h Model (2010-2012)
Oct 3, 2025 06:46 AM
