DIY amp bypass
Old Nov 24, 2011 | 07:35 PM
Arkansas's Avatar
Arkansas
Default DIY amp bypass
Need a diy for bypassing factory amp. Couldnt find one when I searched. And having a post about electronics sent to the correct area isnt any help to ke since it wont ever be answered there lol. Diagrams, pictures, and easy wording for this hick would be great. And is the upgraded alternator needed to do this
Old Nov 24, 2011 | 10:14 PM
Arkansas's Avatar
Arkansas
Well....been moved to a new section.....this questions never gonna get answered now
Old Dec 9, 2011 | 11:21 PM
Shibumi1's Avatar
Shibumi1
aftermarket head unit? i looked to see if i could find a wiring schematic but no such luck...best option would either be run all new wires from new h/u to each speaker... or pulling car apart an matching wires at speakers w/wires at amp...either way door panels come off.. but depending on how much room is in the door boot for extra wire is the real question... a custom shop should be able to take care of this.. it may be a lil beyond some of the guys at BB...
hope this helps... good luck
Old Dec 10, 2011 | 09:13 AM
irishcharm's Avatar
irishcharm
Thumbs up
and thats my turn to chime in like usual lol.
OP you need to state why you want to bypass it like Shibumi1 said. If just bypassing the amp, grab a harness mentioned below from BB (which you will return) and then you can grab a multi meter and figure out your power, ground, switched.....then grab a 9V battery with some leads and "pop" your speakers after the amp to figure out which runs into which door and make note of them. then take the harness and temporarily plug it into the factory harness to find your radio colors...ie wire A on my factory harness is green on the aftermarket one....then take that wire A amd use your multimeter to perform a continuity test from each wire at the deck to the pre-amp on the amp. it takes time but it works.
or if your installing a deck on a non nak system......go to BB and buy the Metra 70-1761 or 70-8112 and dont bypass the factory amp.
not bad for BB guy lol
Last edited by irishcharm; Dec 24, 2011 at 07:56 AM. Reason: until further exploration into 70-8112
Old Dec 10, 2011 | 04:54 PM
Shibumi1's Avatar
Shibumi1
am i wrong in saying BB only installs products that they sell (no outside equipment)
thats what i meant by beyond BB..(beyond what their allowed to do) should have elaborated on that statement...
Old Dec 10, 2011 | 06:02 PM
irishcharm's Avatar
irishcharm
my BB will install anything and everything you can bring in, regardless of how old, new, or pain it is. others are not though. i got a call from a local store saying they were sending me a customer over 1.5 hours to me cuz they couldnt figure out how to install rear speakers in an 09 civic si. no joke. only exception - remote starts have to be BB products.
that aside, any improvements on my amp bypass procedure?
Old Dec 19, 2011 | 07:47 AM
brianmch's Avatar
brianmch
or if your installing a deck......go to BB and buy the Metra 70-1761 or 70-8112 and dont bypass the factory amp.
so you're saying that by using the harness an aftermarket head unit and existing amp can be used?
I've got a dead nak amp in my 99 ls 400 and was told yesterday that a new HU can be installed but I lose my amp & sub, which I don't want to do.
thx
Brian
Old Dec 24, 2011 | 07:55 AM
irishcharm's Avatar
irishcharm
thx
Brian
i watched one NAK amp. My boss retrofitted a varity of different harnesses. i think one was a GM harness and kept the amp. however i couldnt do it again. the above quote was meant for non NAK amps in general, which i have just edited to clarify. From my ideas, an installer without a bunch of random harness cannot though i didnt get to see the back of the deck of a NAK amplified system in the first place. it may be possible using the second harness but im unsure at the moment
Old Jan 23, 2012 | 12:52 PM
bullet1118's Avatar
bullet1118
Will metra 70-1761 or 70-8112 work even if your amp is dying? MY volume is all the way up and sound is very low sometimes just cuts out all the way. How does that piece work is the signal still going through the amp? Am I still going to have low volume with aftermarket deck since its still going through the amp or is it actually bypassing and using the decks power. Not looking for a system just want to hear my radio over the heater without a whole lot of wiring. 96 es300
Old Jan 24, 2012 | 06:31 AM
irishcharm's Avatar
irishcharm
no. they are harness used for bypassing and replacing radios. if you amp is dying, then your amp is dying. there is nothing to do about that, replace the amp or get a new radio/amp setup.
the piece is literally just a harness that is used to adapt from factory to aftermarket connections. thats all. its isnt a miracle cure for anything at all and in your current circumstance bullet, it is useless.
junkyard to find a NAK amp.
amp bypass = not using amp. bypassing it. therefore on deck power.
amp integration = using the amp. integrtating it.
Old Jan 24, 2012 | 01:01 PM
bullet1118's Avatar
bullet1118
Thanks Irishcharm I have a spare deck so guess i'll get that and bypass the amp and use the decks power. But I'm guessing now I'll have more sound but it will sound like crap because the factory stuff is all meant to work together right. Thanks for the info much appreciated!
Old Jan 24, 2012 | 07:13 PM
step2me's Avatar
step2me
NEED HELP.....i have a 2000 gs400 with navi want to change the door speakers and add a 4 channel but cant find the adaptors no where..thats problem one .....second problem is i dont know how to wire the speaker at the factory amp or the input of off the factory amp wires to get RCAs please help pics are welcome......THANKS
Old Jan 29, 2012 | 05:52 AM
irishcharm's Avatar
irishcharm
1. factory navi? replacing navi? "any where"? bypassing factory amp i assume?
2. go purchase a summing device or a line output converter. and hook that up to your speaker leads.
3. take the after market amp and run the output wires to the factory ones that go into the doors and thats that.
Old Feb 26, 2012 | 08:56 AM
ReDLeX713's Avatar
ReDLeX713
instead of starting a whole new thread on this i might as well ask it here real quick..where in the heck is the factory amp on a 93 es300 and what does it look like??? thnx in advance
Pepp
Mar 5, 2019 11:48 AM
SmoakTechn
Oct 21, 2015 10:28 PM
Iparkcars
Sep 30, 2014 05:36 PM
olddog
Aug 12, 2007 01:23 AM
currie
GS - 1st Gen (1993-1997)
13
Oct 14, 2002 12:18 PM
