Quick Question
Old Feb 25, 2012 | 06:03 PM
BradHoff's Avatar
BradHoff
Default Quick Question
If i wire the remote from my aftermarket amp to radio no.2 fuse in my drivers side fuse box, will the amp turn on and off with the radio? I did search but could not find =(
its a 1995 sc400
Old Feb 25, 2012 | 08:05 PM
Big Mack's Avatar
Big Mack
Cool
its a 1995 sc400
No. A fuse is not a switch, so it won't be controlled by the radio. It will supply power so long as the fuse is in the slot. I suggest just adding a simple switch hidden somewhere unobtrusive to turn it on and off. Does require you to remember, though.
Big Mack
Old Feb 26, 2012 | 08:15 AM
BradHoff's Avatar
BradHoff
Oh alright, but will that turn the amp on and off with the car? Or will it be on even if the car is off?
Old Feb 26, 2012 | 10:37 PM
Big Mack's Avatar
Big Mack
Cool
The fuse may be switched by the car, but you'd have to test it. I highly doubt it will be (meaning the amp would stay on), since the radio is switched by the car, but similar to GM, it is run by a bus system, not a direct connection.
Big Mack
GS408
Sep 11, 2022 07:43 AM
minh2015
May 6, 2013 06:16 AM
mike96sc2
Sep 14, 2010 09:17 PM
91ls400own
Jul 9, 2009 12:57 PM
pb22pop
Aug 30, 2007 02:09 PM
