bigger alternator?!!
Old Oct 9, 2001 | 01:00 PM
lxxxs's Avatar
lxxxs
Default bigger alternator?!!
anyone know of a company that makes a direct swap ?
w/ all my audio and other electronics i need more power.
i saw somone had a 180 amp. but i dont know where he got it from.
my car is a 92 sc300
thanx guys, in advance
Jc
Old Oct 9, 2001 | 07:49 PM
sarkastro's Avatar
sarkastro
you might check mr alternator
It's not listed on the site. Just send em an email, and they'll get back to you pretty quick.
Old Oct 11, 2001 | 08:14 PM
Mean Gene's Avatar
Mean Gene
Thumbs up Try Here
JC - Take a look at www.mechman.com or www.ohiogenerator.com. I've spoken with Ohio about a larger alternator for my GS4 & they said they could rewind a stock alternator for some more output ( maybe 180 amps ). I've seen a lot of Ohio products in some heavy hitters on the SPL circuit so I know those are built solid. Don't know about your SC3 but the GS4 factory alternator is rated at 110 amps ( probably a cold rating ). If ya only need extra power for your stereo, consider a Jacob's Accuvolt. www.jacobelectronics.com Good luck!
Old Oct 12, 2001 | 11:16 AM
///MDex's Avatar
///MDex
If you pump up the output of the alt, do you need to exercise caution on down the flow? i.e. the lines that pushing that power to the rest of the car or is there a regulator somewhere?
Old Oct 12, 2001 | 06:15 PM
Mean Gene's Avatar
Mean Gene
Talking No Probs!
Dex - No problems further down the line as the higher output alternator just provides extra amperage & not higher voltage unless U have an adjustable voltage regulator. There's where u need to exercise caution - we had one on the crank-it-up van & when we juiced it up to 16 VDC, we blew the headlights!!:eek: Those RF amps were making some serious power at 16 VDC - unregulated power supply!
Old Oct 16, 2001 | 11:20 AM
lxxxs's Avatar
lxxxs
i cant seem to find anything on the ohiogenerator.com and the link is no good
ive heard of them before but i still cant locate them.
i saw the acuvolt and that looks promissing but i need the alternator for my othe rpeices the fans the ignition the piggy back computer, etc...
any more links or a number for the ohio place would be cool
thanx
Jc
Old Oct 16, 2001 | 11:31 AM
///MDex's Avatar
///MDex
go to www.yahoo.com, and in the search box type
"ohio generator"
and use the quotes; several hits where I'm sure you can dig up the info you need
Old Oct 16, 2001 | 06:56 PM
Mean Gene's Avatar
Mean Gene
Smile Ohio Generator
JC - Guess their site's down. Call them at 330-875-6677. FYI - they're in Louisville, Ohio. Their fax number is 330-875-6688. Good luck with your project!
robertoyou
Performance
12
May 15, 2010 01:55 PM
ted920
Aug 2, 2006 08:43 AM
Neo
Maintenance
Nov 30, 2004 06:29 PM
retrodrive
Oct 29, 2002 09:42 PM
