Rear camera install?
Old Nov 18, 2005 | 05:20 PM
Gs L-tune's Avatar
Gs L-tune
Default Rear camera install?
Anyone install rear camera for GS? I have Eclipse AVN2454 and I just bought the Rear Camera try to put it on but i dont know where to mount it. Can someone tell me where is the best place to mount? I'm thinking the key hole any other idea?
Old Nov 18, 2005 | 06:27 PM
Mr GS400's Avatar
Mr GS400
I put in a Pioneer rear view camera in my GS400 about 6 weeks ago. I elected to mount it in the upper center of license plate recess (directly below the key hole). It's resting against the license plate frame. I just had to drill a single hole for the video/power wire and 2 small holes for the camera mounting bracket (mounted behind the license plate). The camera & bracket are black (same as my car and license plate frame) so it's barely noticeable.
I've seen rear camera installs in the trunk key hole. That defeats the key entry into the trunk and requires more work than I wanted to take on. Plus, the Pioneer camera was too large to fit in that hole.
Hope this helps.
Arnie
Old Nov 18, 2005 | 07:01 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
I used the cable from the Eclipse camera and ditched the blocky camera unit itself in favor of a keyhole camera.
Plugs in and works like the eclipse without the black box.
Old Nov 18, 2005 | 10:09 PM
Gs L-tune's Avatar
Gs L-tune
Dave is it easy to remove the lock from the keyhole? I like ur set up really clean thats exactly how i want mine to be like
Old Nov 18, 2005 | 10:44 PM
Indio's Avatar
Indio
Here is another idea, only had to drill one hole and the cam is protected by the license plate cover.
Old Nov 18, 2005 | 11:43 PM
cliffud's Avatar
cliffud
Former Vendor
Can I see pictures of your setup?
Thanks!
c.
Hope this helps.
Arnie
Old Nov 19, 2005 | 05:39 AM
GSXLEX's Avatar
GSXLEX
OK Dave..spill the beans..Im working on that now.You know I have the 5435 and trying to figure out what to do to keep the functionality of the Eclipse cam..ie auto reverse and aspect ratio.Will the E camera fit in the keyhole..If no..what camera did you use and could you provide a link??..Thanx!!!
Old Nov 19, 2005 | 01:42 PM
Mr GS400's Avatar
Mr GS400
Thanks!
c.
I downloaded a few images to the 'Gallery'. Look under Mr GS400.
Anybody have brief description on how to download images to a forum reply?
Old Nov 19, 2005 | 01:54 PM
Neo's Avatar
Neo
The One
He has the 2454. He bought a different camera that fits in the keyhole and used the wiring harness from the BEC103 (which is now BEC104) camera. The BEC camera will not fit in the keyhole.
I'll let him tell you what camera he bought. It actually might be in a CL thread somewhere.
ny888
Sep 18, 2021 02:24 AM
Neophyte2b
Feb 8, 2019 10:10 AM
lexusalexm
May 1, 2015 02:09 PM
is250cpo
CT 200h Model (2011-2017)
Jun 28, 2011 06:43 PM
eddiec
Feb 8, 2006 08:19 AM
