Subs in Parallel....Help.
Old Jul 13, 2004 | 01:00 PM
TwentyTen's Avatar
TwentyTen
Default Subs in Parallel....Help.
Hi CL. I need to run my subs in Parallel to get a 2 ohm load.
To do this do I have to connect the [+] of speaker A to the [+] of speaker B to the [+] output of the amp and repeat for [-]? Or can I just splice [+] wires together from both A and B and connect them to [+] on the amp?
Old Jul 13, 2004 | 01:31 PM
rjsmetal's Avatar
rjsmetal
Default Wiring in Parallel
As long as all the positives (+) and negatives (-) are grouped that will count work as a parallel connection. So if you wanted to you could hook up both speakers on separate wires and splice the two + together and two - together. As long as at the amp all the positives are connected to the positive terminal and all the negatives are connected to the negative terminal. METAL
Just remember when wiring in Parallel you bring down the resistance (ohms)!! Make sure your amp can handle the load!!
2 8ohm = 4 ohm
2 4ohm = 2 ohm
And each VOICE COIL COUNTS AS A SEPARATE SPEAKER!!!!
If you are still confused just ask me.
Old Jul 13, 2004 | 02:37 PM
TwentyTen's Avatar
TwentyTen
Thanks RJS!
So just to make sure, i can run the cables like this:
Old Jul 13, 2004 | 07:40 PM
rjsmetal's Avatar
rjsmetal
Default YOu got it!!!
That will work exactly right, my only suggestion would be make sure you use larger wire were the paths are combined.....
........The best stereos are only as good as the wire that supports them! METAL
Old Jul 14, 2004 | 09:11 AM
TwentyTen's Avatar
TwentyTen
Default Re: YOu got it!!!
Thanks. I agree, that's why I have all Stinger interconnects Right now I have 14AWG lamp cord connecting my subs but I've been told that lamp cord is only good for home speakers because cars introduce more noise.
Old Jul 14, 2004 | 02:30 PM
TurboSC's Avatar
TurboSC
I was just talking to RJ (he is a personal friend of mine, who is also doing my stereo btw ) and he said that is correct, car RCA's are wrapped differently to deflect noise. He made me get the Stinger Expert RCA's they were over $200 but it is worth it!
Old Jul 14, 2004 | 03:29 PM
TwentyTen's Avatar
TwentyTen
Thanks, I have Stinger Hyper Series 4 channel cables running from the head unit to the 4 channels amp and Stinger Hyper Series 2 channel cables running from the head unit to the sub amp.
I'm using the lamp cord from the sub amp to the speakers. I'll upgrade it soon. Do you know what kind of difference it will make?
Old Jul 14, 2004 | 09:43 PM
rjsmetal's Avatar
rjsmetal
Default speaker wire
Using better speaker wire will help as a car is just a spawning ground for Radio Frequency Interference (RFI), the most noticable difference will be in the RCA interconnects as the are moving such a weak signal but better speaker wire will help keep out any "noise" and also will have less resistance inturn helping your speaker and amp work better. METAL
Free Agent
Feb 5, 2009 11:03 AM
TomLee
Dec 2, 2007 10:31 PM
kingomar
14
May 6, 2007 11:20 AM
2Fast0
May 7, 2006 01:27 AM
antn
Aug 7, 2005 12:08 AM
