capacitor cap question
Old Jan 22, 2004 | 07:16 AM
  #46
koreanpers's Avatar
koreanpers
Originally posted by RSTSpeed
I'm suprised you're having dimming issues with 8AWG wiring; I've got 4AWG split into 2 8awg lines and no dimming problems at all... Combine, my amps push out a maximum of 1580 watts; I'm also running an Optima RED Top - I know the yellow tops are more popular, but the Red top has more cranking amps, more cold cranking amps, and just SLIGHTLY less "run time", or whatever you call it when you jus chill with your stereo on. It's more suited for racing setups.
he is running 8awg back frm the batt...you are running 4 awg from the batt to the cap. it makes a huge difference
Old Jan 22, 2004 | 08:27 AM
  #47
jmecbr900's Avatar
jmecbr900
First: PPI= Precision Power Industries. It is a good amp.
Second: The "gain" control on an amp is NOT a volume control. It is designed to adjust to match the power of the inputs prior to clipping. In other words, if your HU puts out 3V thru the RCA's you may have the gain up to 1/2 way. If your HU puts out 8V's, your gain should be considerably lower and therefor net a cleaner sound. The higher the gain is turned up, the dirtier the sound because you are introducing noise into the sound. We could go much deeper about matching the gains to the inputs, but I'm don't wanna confuse anyone. In a nutshell, it is NOT a volume control. It is supposed to be set at the lowest possible setting that will not make the sound spike as you turn up the volume on the HU. It should be smooth.
Third: Always use the biggest cable possible of the best quality possible. Too much is never enough in this case. At worst, you'll waste a little money because you went into overkill. That's still not bad though. For the system in question, I would suggest at least 4ga and preferably 2 ga. 2 ga. should be plenty.
Fourth: The cap should be ground by itself, and the amp should be ground by itself. Do NOT ground them thru each other or with each other. It does make a difference.
Fifth: The amount of amps any system draws is based on lots of factors. How the amp is wired to the spkrs (impedence), What kind of wiring (too little hurts here), How hard are you driving the amp (wiring of the spkrs and how high the gain is) will all change the way the amp draws current. There is no way that some of you guys are drawing 130+amps from your system. If you were, you would kill the car on the spot if you didn't have a high output alternator installed (200amps or better). Most single amps will draw about 20-30 amps max if ran correctly. Keep in mind that you should have an inline fuse. What amp rating is it? I bet it's not 150 amps though. Think about it.
Old Jan 22, 2004 | 09:01 AM
  #48
ROLNLEX's Avatar
ROLNLEX
I like jmecbr900 he said mostly the same things I did...just more technically...My pioneer premier deck when I had the PPI 1000w had a 4v output and I was a bit under half...maybe 1/3
Old Jan 22, 2004 | 11:57 AM
  #49
RSTSpeed's Avatar
RSTSpeed
Originally posted by rscott
US Acoustix is one of the brands loved by the audio guys =)
I have an amp in my car for my components. Clean and efficient power.
ps. Im not offended
k.
Yea, but I don't have a cap at all
Originally posted by ROLNLEX
*added after reading back through posts* and a loooong time ago when I posted last (I went to bed early, trying to get better from being sick) I meant that every car IS different (I was messed up on Tylenol Cold & Sinus Maximum Strength Nighttime)
lol, nice...
Good point.
Old Jan 22, 2004 | 12:34 PM
  #50
elclassico's Avatar
elclassico
Default good info
good info. so ground the cap and the amp to the same place on the car chasis? so if what you were saying is true then i would only need 4 guage for now, but with a jl 1000/1 amp, you would probably need a 2 guage? by the way why is 2 guage so hard to find, crutchfield doesnt even carry one..>
Old Jan 22, 2004 | 12:41 PM
  #51
jmecbr900's Avatar
jmecbr900
Just as a follow-up to amp draw:
Most Lexi have 80-110amp alternators. It is impossible to draw 130 amps on a 110 amp alternator. It is also impossible to draw even 100 amps while the car is running because the second you press the brakes or turn on the headlights, you will kill the car since it doesn't have enough current to do everything at once. Get it?
Most amps have a max amp rating in their specs. This is a rating for amperage at wide-open volume, gains up, and wired at the amps lowest impedence (probably around 2ohms). A high current amp, like the Orion HCCA series amps, that can go to ultra low impedence (.5 ohms) put out a ton of power but also draw a ton too. A single Orion HCCA amp wired to a pair of DVC subs can pull as much as 80 amps by itself. This is an extreme example of course. Keep in mind that as you make the amp work harder, the more power it needs.
Old Jan 22, 2004 | 12:53 PM
  #52
jmecbr900's Avatar
jmecbr900
Default Re: good info
NO!! Ground the cap somewhere and ground the amp somewhere else too. The point was to ground them individually, NOT together.
Your cap should be wired like this:
+ from batt to + cap
- from cap to ground
+from cap to + of amp
- from amp to ground
Use the biggest gauge wire you can afford. You should be able to go to any local stereo shop and buy any size wire you need. You may wanna call around to be sure and not waste your time. Remember that the size of the wire is due to 2 things: distance to travel and amount of power needed. The further away you have to go, the bigger the wire needs to be to have a good net result. Think of it like a garden hose. At the spigot you have a lot of water pressure. If you add 5 50ft sections, Pressure will be low at the end of the line. If you use a single 50 ft section, you will have more pressure than the 5 50ft section example. Get it?
So to answer your question directly, yes a 4 gauge will probably work fine, but a 2 gauge will work better. It all depends on what you can get your hands on.
BTW, just for reference, I have paid as much as $10/ft for big gauge wire.
bass911
45
Sep 20, 2013 10:10 PM
charmz
Jul 7, 2008 08:19 PM
Kohinoor
12
Jan 10, 2008 05:49 AM
engin_ear
Oct 1, 2006 08:25 PM
andy2003si
Jan 24, 2005 10:33 AM
