Replace the tire or just let it be?
Old Jul 9, 2021 | 06:49 PM
redhot47fl's Avatar
redhot47fl
Default Replace the tire or just let it be?
So, imperfectly timed for Memorial Day, I found that one of the Bridgestone run-flats on my week-old LC 'vert was losing air. Turned out to be a nail in the middle of the tread, repairable by a willing tire shop but not by any dealer (dealers universally and...flatly... refuse to repair run-flats). It never went completely flat.
I had bought Allstate tire and wheel coverage from the dealer, but I found an open tire shop, which expertly patched the tire for $60. Hasn't lost a molecule of air since. Over many, many years of driving, I've never had a patched or plugged tire fail due to the repair.
The dilemma: Next week, I'll be near the closest Lexus dealership, which is 2 1/2 hours away, for a couple of days. Given that I have the insurance but I'm reluctant to have anybody anywhere work on my car unnecessarily, should I:
1. Have them replace the patched but seemingly perfectly fine tire?
2. Just leave well enough alone and spend my time thinking about more important things?
Old Jul 9, 2021 | 07:40 PM
hoonose's Avatar
hoonose
Stay as you are. Even good dealers can screw up something unrelated to your perceived problem.
Old Jul 9, 2021 | 08:50 PM
74Sprtstr's Avatar
74Sprtstr
choose the path of least resistance. btw, i have had 2 incidences with my bstone runflats, both of which were professionally repaired without
a whimper; i'd suggest anyone who tells you differnt is really just saying f off....
Old Jul 9, 2021 | 08:59 PM
I say leave it.
Old Jul 9, 2021 | 10:23 PM
hoonose's Avatar
hoonose
I forgot to mention I had a total 5 runflat flats on my first two Vettes, C5 and 6. All repaired and never had any other problem. Construction screws every time.
Old Jul 10, 2021 | 01:04 PM
DRGibbons's Avatar
DRGibbons
As the others say above, leave it alone. A professionally applied patch is considered a permanent fix. You're good until you run out of tread.
Note: Run-Flat technology primarily deals with the side wall of the tire and not the tread.
Old Jul 10, 2021 | 01:57 PM
74Sprtstr's Avatar
74Sprtstr
indeed, as you've pointed out in a previous thread, that sidewall will support the 4500lb vehicle with 0 psi pressure...for about a hundred miles
(actually, a quarter of the vehicle...)
Old Jul 10, 2021 | 02:03 PM
redhot47fl's Avatar
redhot47fl
Aye. Didn’t mean to imply otherwise.
Given the unanimity of opinion - a rare thing here - I shall let it be. Thanks to all who responded.
Old Jul 10, 2021 | 02:07 PM
74Sprtstr's Avatar
74Sprtstr
uh not to not let it be, your tire insurance probably covered your flat repairs
Old Jul 13, 2021 | 11:07 AM
DaddyFES's Avatar
DaddyFES
If you have a tire warranty they'd likely replace the tire. Not repair since as you stated it's a run flat. However, you'd then want to replace at least 2 tires so the tread is even. If you're not willing to do that, I agree with everyone else. Let it be!
andyboy
Jun 26, 2019 09:06 AM
RollingBlu
RX - 4th Gen (2016-2022)
Apr 20, 2018 08:25 AM
dinardalvi
IS F (2008-2014)
May 21, 2012 11:25 AM
Leechiro
Maintenance
Apr 5, 2006 01:56 AM
