Spacers for 2024
Old Nov 20, 2025 | 04:12 PM
  #46
np20412's Avatar
np20412
Looks great!!
Old Nov 20, 2025 | 05:55 PM
  #47
Zeus69's Avatar
Zeus69
Just bought four 20 mm spacers with extended bolts from a well-established Forum member (thanks @np20412 !) and looking forward to getting them on my 2024.
Old Jan 1, 2026 | 06:29 PM
  #48
GreggyG's Avatar
GreggyG
Originally Posted by np20412
Yes agree! I test fitted the fronts today with the smaller bolts just to see the look. They are sending me the right size bolts by Monday so I'll replace them then before I drive it anywhere. 20mm is indeed perfect. I thought it might be 5mm too shallow and should have gone with 25mm but then clearly the bottom of the wheel would poke quite a bit. As it sits now it's nearly flush at the bottom of the wheel (slight poke) and slightly tucked at the top due to the negative camber. I think the poke that would result at the bottom from having it flush at the top would be too much for me.
is this pic of the fronts with the 20mm installed? or just the rear 20mm?
Old Jan 2, 2026 | 04:51 AM
  #49
np20412's Avatar
np20412
I think it was both. If I had to do it again I would get 22-25mm, but that's just personal preference after having aftermarket wheels that sit a little farther out
CaptRog21
May 18, 2019 10:49 AM
808_GS400
Jan 31, 2012 07:16 PM
CleanCL
Wheels and Tires Classifieds
Oct 13, 2010 11:00 PM
stockySC4
Apr 9, 2010 10:47 PM
