Question about LC
Old Dec 30, 2025 | 06:54 PM
oceanp's Avatar
oceanp
Default Question about LC
I have a 2025 IS 500 and am pretty close to pulling the trigger on a new LC. One of my concerns is I live in a community with speed bumps. Could someone tell me the clearance from the bottom of the front bumper to the ground. My IS clears with no problem. I evened looked to rent one for a day or two before plopping down 120k to make sure it works for me. The IS is comfortable, has much smaller doors and has good visibility. don't want to make a huge financial mistake. Any feedback is really appreciated.
Old Dec 30, 2025 | 06:58 PM
355F1's Avatar
355F1
You'll be fine.
It isn't low.
Old Dec 30, 2025 | 07:27 PM
kirkd1's Avatar
kirkd1
5.2 inches of clearance and an approach angle of 12.1 degrees.
Old Dec 30, 2025 | 07:46 PM
oceanp's Avatar
oceanp
Thanks much.....Seems like every used LC I've seen has the bottom of the bumper thrashed pretty good...
Old Dec 30, 2025 | 07:54 PM
355F1's Avatar
355F1
I've had mine for 5 years and have never even once scraped the front bumper on anything.
Old Dec 30, 2025 | 08:32 PM
Enzo954's Avatar
Enzo954
My neighborhood has tons of speed bumps, and I clear them fine. My LC is also on lowering springs, so stock height you'll be fine.
Old Dec 30, 2025 | 09:08 PM
400Mman's Avatar
400Mman
@oceanp
According to Edmunds and Lexus of Canada,
2025 IS 500 ground clearance is 5.5 in.
LC 500 ground clearance is 5.2 in.
Old Dec 31, 2025 | 04:04 AM
np20412's Avatar
np20412
This is mainly because people don't understand generally how long the nose is. The thrashing is not likely from speed bumps but rather from steep ingress/egress points and more likely curb stops/parking stops.
Old Dec 31, 2025 | 09:20 AM
Metal1's Avatar
Metal1
This is where you really miss a front end camera.
Old Dec 31, 2025 | 12:01 PM
tecman's Avatar
tecman
The aftermarket front camera is good for a direct curb approach, but it’s pretty much useless at any angle. That’s probably where the 360° system shines.
Old Dec 31, 2025 | 12:06 PM
Hythe's Avatar
Hythe
Yep, one of the best things about the 2024+ models...
Old Dec 31, 2025 | 03:51 PM
SRMLS's Avatar
SRMLS
I had the same concerns when I bought mine. I ended up buying a AutoMods front bumper skid plate. Have'nt installed yet as needs to be on a lift. I'm going to have my dealer install it when I get my first oil change done.
Old Jan 1, 2026 | 04:08 PM
ratchettt's Avatar
ratchettt
100% my experience. Two contacts. One from parking-stops. Other steep ingress/egress. Both 6 months apart in which I wrongfully thought I'd learned better. Many speed bumps with no issues.
Old Jan 2, 2026 | 09:20 AM
StuM's Avatar
StuM
Default Speed bumps
Have never scraped mine (‘24 coupe). Yet, just to protect it, I applied Slip-Pro stick on protectors on the bottom of the lip, just in case. Do it on all my low front end cars.
Mar 21, 2025 04:56 PM
Badhobz
Aug 4, 2022 12:25 PM
BigBang
Oct 18, 2011 03:50 AM
mrlextasy
Sep 17, 2011 09:58 AM
lexusboi
Automotive Care & Detailing
Nov 6, 2005 04:59 PM
