Strange jolt while turning??
Old Sep 5, 2023 | 12:03 PM
Enzo954's Avatar
Enzo954
Default Strange jolt while turning??
I have 2022 that I bought used with low mileage. Looks brand new. It currently has about 2000 miles on it. Occasionally when I back out slowly from a parking space and turn the wheel while going backwards I get a quick jolt or jump in the steering. This occurrence sometimes even happens while turning slowly into a parking space. It's a strange sensation that is hard to describe. Almost like the tire is sticking and then it just jolts into place. Has anybody experienced this?
Old Sep 5, 2023 | 03:19 PM
GatorGreg's Avatar
GatorGreg
I have not but I'm guessing it might be related to the Torsen limited slip differential? On my Jeep Wrangler, if I lock the rear diff and then try to make a turn on dry pavement, it will react the same way that you are describing but that would be normal with a rear locker engaged. For a limited slip differential it should not do that - so perhaps your rear diff fluid is running low or may need to be changed?
Old Sep 5, 2023 | 03:34 PM
Enzo954's Avatar
Enzo954
My car doesn't have the limited slip diff.
Old Sep 5, 2023 | 03:44 PM
GatorGreg's Avatar
GatorGreg
Oops, well in that case:
Old Sep 7, 2023 | 05:36 PM
dumb question but have you checked the tire pressures?
what tires does it have?
Old Sep 19, 2023 | 07:16 PM
Enzo954's Avatar
Enzo954
Tire pressure is good. I have the original Michelin run flats on the 21" rims. Car has under 2k miles on it. It happens most of the time while in reverse and turning the wheel backing out of parking spaces. Sometimes while turning into a parking space.
Old Sep 19, 2023 | 08:26 PM
flowrider's Avatar
flowrider
Veteran: Air Force
My Reply to another thread:
Originally Posted by sickpuppy
It's my experience that this is a common condition on Lexus vehicles when the steering wheel is turned full lock. Nothing to do with the LSD. It happened on my ISF and happens on my LC. If your juddering is happening at full lock, it's normal and nothing to worry about.
​​​​​​​If this happens at full lock - It's normal on a Lexus.
KingR413
Jul 18, 2021 07:10 AM
Philips
Jun 4, 2014 11:11 AM
OneSiCkF
IS F (2008-2014)
15
Mar 3, 2014 10:21 AM
rich_4
Nov 20, 2008 09:24 AM
starstreak
Aug 9, 2007 01:30 PM
