Will those wheels fit? START HERE.
Old Apr 20, 2013 | 06:51 PM
  #4486
ArtG's Avatar
ArtG
Hi CL
I'm currently have 19 wheels with the following specs: 19x8.5 +35 and 9.5+40 with 225/35 and 265/30. Been driving around for 2 month, ride is pretty harsh which i dont really mind, but i just found out that one of my wheels bent (rear passenger) and my frint driver tire start cupping. So I'm thinking about getting 18 wheels with 40 series tires.
My question is, will the ride quality be better with 40 series tire, and will the chance of bending wheel lower with 40 tires?
TIA
Old Apr 20, 2013 | 08:16 PM
  #4487
toystry's Avatar
toystry
What's the max size wheels/tires you can run on stock IS350?
Old Apr 21, 2013 | 12:48 AM
  #4488
projectdna's Avatar
projectdna
Originally Posted by 4TehNguyen
I am looking at some new wheels, the 19" LFA style ones in hyper black. Need to get some info if the tires might rub. I do not have a modified suspension. I do have the sport package which is 1/2" lower than stock but thats it and I have no plans to change the suspension.
wheel specs are:
F: 19 x 8.5" +38
R: 19 x 9.5" +45
tires I was looking at:
F: 245/35/19
R: 275/35/19
another persons LFA wheel thread:
https://www.clublexus.com/forums/is-...-wheels-2.html
they'll fit fine. not sure why this needs reiterating, since in the other thread others have documented that they fit fine.
Originally Posted by adule
I'm going to be running a squared setup for my awd (as recommended) on BCR coil overs. More than likely a finger gap or around 25" from the ground to the fenders. The size of the wheels are 18x9 + 30 all around. Should I run a 225/40/18 tire set up or a 235/40/18 setup. I want to try the latter, but if it's going to rub I'll just stick with the first choice. Any recommendations?
225/40-18. move to the larger size if and only if you find that you have plenty of clearance.
Originally Posted by ArtG
Hi CL
TIA
problem is, your tires will be too tall, and your speedometer/odometer will be thrown off.
the difference won't be much between 35 and 40 series tires. you can try wider tires so the sidewalls will be more upright, or tires w/ softer sidewalls (i.e. michelin pilot super sports).
that depends on what you're trying to accomplish.
Old Apr 21, 2013 | 01:07 PM
  #4489
ArtG's Avatar
ArtG
Thanks projectdna, do you mind recommending me tire sizes for 18x8.5 and 18x9.5 with offset 30 and 35. I believe it wont need any fender mods right? I am lowered to no finger gap. Thank you
Old Apr 21, 2013 | 03:39 PM
  #4490
projectdna's Avatar
projectdna
have you tried searching in this thread for those exact wheel specs or something similar?
Old Apr 21, 2013 | 07:05 PM
  #4491
ArtG's Avatar
ArtG
Well I know 19x8.5 and 9.5 offset 30 and 35 with 235/35 and 260/30 will have minimal rubbing , but will 18x8.5 and 9.5 with 225/40 and 255/40 rub? I believe the tire size is stock size for 18 stock wheels. Car is lowered to no finger gap. My goal is to have 18 wheel with minimal rubbing so I can drive faster than using 19.... sorry for all the question and thank you
Old Apr 22, 2013 | 08:02 AM
  #4492
toystry's Avatar
toystry
Just going for a simple wheel/tire combo. Not looking for the tucked inside the wheel wells look, or where some have the tires angled (not sure what that's called). My goal is to fit something that fills up most of the wheel well gap without rubbing or interference. I don't mind modding a little to make them fit but nothing crazy.
Old Apr 22, 2013 | 06:19 PM
  #4493
MamadIS's Avatar
MamadIS
I am buying a set of XXR 521s and they are 18x8.5 and 18x10. I am on BC coils and was wondering if those would fit on my 06 IS350. not sure what the offsets are. tires are 225/40/18 and 245/40/18 if that help.
Old Apr 22, 2013 | 07:04 PM
  #4494
4TehNguyen's Avatar
4TehNguyen
i searched this thread some more and it said 245/35/19 has a narrow window of fitment, so I think I will go with 235/35/19. 235/35/19 is closer to the stock diameter too. I tried 235/30/19 and 245/30/19 but the tire selection was very slim. For the rears probably going to choose 275/30/19
Old Apr 22, 2013 | 11:22 PM
  #4495
projectdna's Avatar
projectdna
i can try and guess based on tire size.
but without the exact wheel offsets, my guess is as good as crapshoot.
if you want to run 245 in the front, you'll need to run 30-series (read: 245/30-19).
Old Apr 23, 2013 | 01:27 AM
  #4496
Stevoe88's Avatar
Stevoe88
Hi guys, looking to get back into some flush wheels. Im debating between 19x8.5 +25 19x10 +25 with 215/35/19 and 245/35/19 or 19x8.5 +35 19x9.5 +35 same tires as first spec except id run a 235 width tire in the rear. I dont mind slight rubbing on the lining too much but im more worried about destroying my fromt fender tabs breaking, ultimately resulting in my bumper tabs all breaking and eventually caving in which was what happened on my 20x8.5/10 +30 set up. I have flared fenders all around with my tabs relocated in the rear. Im pretty low on megan lp streets with no tire gap on stock 18's. if im gonna run into brackets breaking going with the +25 set up id rather just go conservative. Any thoughts?
Old Apr 23, 2013 | 08:16 AM
  #4497
4TehNguyen's Avatar
4TehNguyen
unfortunately the 245/30/19 has a horrible selection of tires with 275/30/19. 235/35/19 opens up a LOT more tires.
Thanks for your all your help
Old Apr 23, 2013 | 11:46 AM
  #4498
ohitsduy's Avatar
ohitsduy
Hey guys I was wondering if yall can help me I just bought a set of wheels and there kind of aggressive I plan on running some stretch tires what kind of sizes do yall recommend? there 19x9 +22 in the front and the rear is 19x10 +32 and im on coilovers also
Old Apr 23, 2013 | 06:02 PM
  #4499
static250's Avatar
static250
225/35 front and 245/35 read. You will need to roll fenders and modify front liners and bumper tab.
Old Apr 24, 2013 | 12:11 AM
  #4500
ohitsduy's Avatar
ohitsduy
Thanks for the help bro!
