Will those wheels fit? START HERE.
Old Jul 8, 2013 | 05:14 PM
  #4636
HKSMatador's Avatar
HKSMatador
I have an IS350 sitting on Eibach Springs and Tokico struts. I want to run the 19" Varrstoen ES2's. What offset would be best to avoid much fender mods. Will this setup need a lot of work?
Varrstoen ES2 Front: 19x9.5 +30 Rear 19x10.5 +30.
The place I ordered them from said +30 will not clear IS350 brakes? Any help is appreciated.
Old Jul 10, 2013 | 10:50 AM
  #4637
TLRD's Avatar
TLRD
Trying to decide on a tire size.. I have 19x9+26 and 19x10+38 and will be just about rim on fender in the front and hopefully slightly tucking in the rear. Any ideas on what tire size I should be looking at?
Old Jul 11, 2013 | 11:51 AM
  #4638
ShowOffGPE's Avatar
ShowOffGPE
I have a 07 IS250 Looking to put 18x10 all the way around. What offset is needed? I know 18x10 can fit on rear, not too sure about front. Should I go staggered? I was also told that 18s would look too small and to go 19s. Any suggestions?
Old Jul 11, 2013 | 05:15 PM
  #4639
susm123's Avatar
susm123
20X9 +23 225/30/20 and 20x10.5 +30 255/30/20
Dropped 2" on Road Magnets
Will they fit on a 2008 Is250?
Old Jul 12, 2013 | 05:03 AM
  #4640
bob4256's Avatar
bob4256
Will they fit? Yes but you will need to roll your fenders and possibly relocate your front fender tabs.
Old Jul 14, 2013 | 12:23 AM
  #4641
ldc's Avatar
ldc
Hey guys, would 245/45/18s with +30 ET rub on the rear (has 1.1 inch drop on Tenabe)?
From the image i think i'm in touble.
https://www.clublexus.com/forums/is-...2wd-is250.html
Old Jul 14, 2013 | 09:18 AM
  #4642
RVCAis250's Avatar
RVCAis250
You will absolutely need to relocate your fender tabs. On top of that, you'll need to roll all 4 fenders and slightly pull the rear.
That image is by no way a proper means to estimating the fitment. Width of the wheels will be beneficial to answer this question, but since you didnt provide it, I'm going to guess that it's a 9.5-10" wide wheel. In which case, at that height, I believe you shouldl be fine.
Old Jul 14, 2013 | 09:21 AM
  #4643
RVCAis250's Avatar
RVCAis250
Never mind then, I just looked at the link you posted and you'll be just fine with 18x8. No rub whatsoever.
Old Jul 14, 2013 | 11:58 PM
  #4644
DFig619's Avatar
DFig619
2012 IS250 RWD
Front: 19x8.5 +35
Rear: 19x9.5 +30
Not lowered YET, but plan on lowering it so that the tire is 1 to half a finger gap space
I absolutely do NOT want to roll fenders or stretch tires. Could I possibly use this rim specs?
I'm not sure what tires I would get but could you guys recommend some for a good fitment?
Old Jul 15, 2013 | 12:01 AM
  #4645
icrash's Avatar
icrash
Looked through threads, but couldn't find the answer. Please help.
For AWD willing to put 19x8,5 (offset 35) all around with 235/40/19 tires. On stock ride height.
Will this setup rub in front/rear? Any mods needed?
Thanks a lot!)
Old Jul 15, 2013 | 05:16 PM
  #4646
ldc's Avatar
ldc
Originally Posted by DFig619
2012 IS250 RWD
Front: 19x8.5 +35
Rear: 19x9.5 +30
I have the same on font and with 1.1" drop, touches a little on the inner linen of the arch but no need to do anything.
Fo the rear i think you will hit.
Old Jul 15, 2013 | 07:12 PM
  #4647
SCWB's Avatar
SCWB
2012 IS250 RWD
Front: 19x8.5 +35
Rear: 19x9.5 +30
Ok, I am currently running:
19x8.5 +35 with 235/35/19 front
19x9.5+35 with 255/35/19 Rear
Lower about 1.3 inches all around (1.5 finger gap front, 1 finger gap rear).
Driving aggressively with this set up, the front has very very very slight rub. So slight that it has just left a few faint scrub marks on the fender liner, no holes at all.
Rear is 100% rub free with about 5-10 mm clearance from rear fender edge to the tire shoulder. I can use 265/30/19 without problem.
I can go .2 or .3 inch lower without any problem but I don't want to spoil the fun by having to be very careful everywhere I go, so I just leave the ride height at this 1.3 inches.
In your case, if you want to run to 1 finger gap, you will experience slight rubbing in the front. May be only over extreme bumps or potholes. I don't think you have to worry about it.
In the rear, with 9.5+30. it is a very close call of rub-or-no-rub territory. Depending on the tire sizing and brand, you may be able to get away with rubbing problem.
Old Jul 15, 2013 | 07:36 PM
  #4648
DFig619's Avatar
DFig619
Thanks for your guy's feedback!
SCWB, you have a picture of your car? I would like to see how low you are, my "1 finger" distance is just to get an idea of how low, might go that low cause its my DD and I dont want to be damaging anything to much.
Old Jul 21, 2013 | 03:51 AM
  #4649
jimmyjam's Avatar
jimmyjam
Default will these Vossen 086 staggered wheels and tires fit?
Hey guys, Im looking to get these bad boys, on H & R sport springs. I am very new to this and have been trolling this site for a while learning lots! BUt I want to make sure these guys will fit. Any help would be awesome!
Color: Dark Matte Graphite Gunmetal Gray
Fronts: 20x9 +20
Bolt Pattern: 5x114.3
with Hankook Ventus V4 ES H105 235/35R20
Rears: 20x10.5 +25
with Hankook Ventus V4 ES H105 255/35R20
Old Jul 21, 2013 | 09:06 AM
  #4650
bob4256's Avatar
bob4256
Fronts: 20x9 +20
Rears: 20x10.5 +25
Your going to need fender mods. Rolling all your fenders and relocate your bumper tabs. Might want to go with 235/30/20 and 255/30/20 instead
