Will those wheels fit? START HERE.
Old Apr 3, 2013 | 10:23 AM
  #4441
projectdna's Avatar
projectdna
Originally Posted by k1ngph1l
I just test fit the wheels today and looks like they are definitely not a 10.5 and more like an 11 as the rims are sticking out almost an inch further than my finder, which is already slightly pulled. If the fender gets pulled anymore it will start getting wavy. Looks like my fender can clear the tires but not the wheel itself.
you didn't think that you could tuck tire w/ those specs, did you?
Originally Posted by SlapnUup
well i guess ill go rapid fire here.... next option i got on these wheels is to jump up to 20". specs would be 20x9+15 (to clear calipers he says) and 20x10+15. I would like to run 225 and 255. The width seem alright but these offsets are killing me. What do you guys think?
245 in the rear. stay with 30 series. still sucks for a 60-mile daily commute.
Originally Posted by dci4life
Is there a Miro Wheels thread? (could NOT find one while searching on my iPhone)
no, because there aren't enough miro wheels owners to warrant a thread for said brand.
Just ordered some for my 2IS and anxious to see how they will fit. I'm on H&R Sport Springs 1.4F&1.2R and ordered the Miro 398 in an 18x9.5+20. My rear fenders have been rolled and i plan to get my fronts rolled. How crazy of camber will I need to do?
-pic snip-
you won't need to. go low enough, and the OEM suspension geometry will camber the wheels. you'll probably need to run 225's to get the sidewalls to stretch and clear the fenders. make sure the fenders are rolled flat, and all four fender tabs are taken care of.
Old Apr 3, 2013 | 01:36 PM
  #4442
Griiix's Avatar
Griiix
this thread is a life saver
Old Apr 4, 2013 | 10:47 AM
  #4443
Acevision's Avatar
Acevision
Hi i need some help, can i use 19" 8.5" 5x114mm ET15 all around for my is250? stock springs
Old Apr 4, 2013 | 11:10 AM
  #4444
projectdna's Avatar
projectdna
not without fender work in the front.
Old Apr 4, 2013 | 09:05 PM
  #4445
1ISto2IS's Avatar
1ISto2IS
what do I need to do to make these fit? thanks in advance
Attached Thumbnails Will those wheels fit?  START HERE.-3ec3fa3ia5i35n55m5d437997712deb3218c4-1-.jpg
Old Apr 4, 2013 | 09:17 PM
  #4446
laobo979's Avatar
laobo979
Same as every one else who on here roll,pull,stretch,negative camber and bumper tab relocate.
Old Apr 4, 2013 | 10:18 PM
  #4447
projectdna's Avatar
projectdna
best answer for those who don't bother to search in this thread.
(with all due respect, your wheel specs (or something close to them) have been covered so many times that those who contribute in this thread are simply T-I-R-E-D of answering the same questions over and over again.)
Old Apr 4, 2013 | 11:40 PM
  #4448
Griiix's Avatar
Griiix
what tires for,
19x9.5+22
19x10.5+24
I have tein ss, spc rear camber, spc front ball joint.
Old Apr 4, 2013 | 11:47 PM
  #4449
infate's Avatar
infate
Originally Posted by griiix
what tires for,
19x9.5+22
19x10.5+24
i have tein ss, spc rear camber, spc front ball joint.
225/35/19, 245/35/19
If you're brave, 215/35/19, 235/35/19.
Refer to this to see if you like the stretch or not.
Old Apr 5, 2013 | 08:46 AM
  #4450
BernieIS's Avatar
BernieIS
I have tried looking for the answer to this but since these are 20 inch wheels there does not seem to be a definite answer that I could find. Sorry if I did miss it.
I am trying to fit 20 X 10.5 +25 in the rear with a 255-30-20 and a 20 X 8.5 +25 in the front with a 225-35-20 is there anything outside a standard roll and pull that I will need to do? I am lowering the car on Megan LP coilovers so I will be able to set the height as I see fit.
Old Apr 5, 2013 | 10:03 AM
  #4451
projectdna's Avatar
projectdna
i would stick strictly w/ 30-series for 20" set-ups.
having said that, i'd go 225/30-20 + 245/30-20.
and depending on how low you plan to go, expect to shave down the fender tabs in the rear and remove the fender bolts up front while bending the fender tab flat against the inside wall of the fender.
Old Apr 5, 2013 | 02:05 PM
  #4452
Stavros's Avatar
Stavros
Thinking of getting the following. Car lowered on Eibach springs.
Front: 18x9 ET35
Rear: 18x10 ET45
What tires would fit best? Do I need to roll the arches?
Thanks
Old Apr 6, 2013 | 02:51 AM
  #4453
ApokC's Avatar
ApokC
Avant Garde M310s
Front: 19x9.5 +20mm
Rear: 19x11 +18mm
Fenders already rolled, but I'm dropped 2" on Megan EZ's
Old Apr 6, 2013 | 03:31 AM
  #4454
Griiix's Avatar
Griiix
Originally Posted by ApokC
Avant Garde M310s
Front: 19x9.5 +20mm
Rear: 19x11 +18mm
I think ure going to have to pull quite a bit........
Old Apr 6, 2013 | 04:54 AM
  #4455
BernieIS's Avatar
BernieIS
Thank you for the quick reply.
