Engine cranking/startup noise (merged threads)
Thanks for the info! How much does that cam gear TSIB usually run? Ive had that knocking noise happen a couple times now.
If your car is out of warranty you'll be paying out of
pocket for any work regardless of if there's a TSIB for it or not.
Only recalls are free outside of warranty.
(and even if you were in warranty having aftermarket suspension parts has no relation to having a warranty (TSIB) engine repair done).
Also mine is alot louder then that! its real noticable. Im worried now. And im out of warranty.
wow i have this same exact noise from this user from youtube. i believe its the rattle sound every one is talking about. Should i have the dealer look into it?
http://www.youtube.com/watch?v=Zj3xm-LhWqs
I had this same issue about two months after owning my 2007 Lexus IS350 (purchased new).
I brought it up several times to DCH Lexus of Oxnard and each time it was the same story.."Unable to duplicate"
They weren't able to duplicate until I was 1000 miles past the warranty. Then all of a sudden they could and of course, I would have to pay for the fix.
Hi guys,
I posted some of the original comments on this issue back in 2008 when my IS250 was the first IS250 in the UK to be rectified (The Reading dealer had my car for a couple of weeks while they recorded every stage of the dismantle and rebuild as apparently my engine was slightly different to those in the American tech bulletin)
My last post was in July 2008 and I can still report that I have not had a recurrence of the knocking and I've just surpassed my 50k service.
Good luck all.
Good luck all.
Nobody with an 09 IS350 have this problem? Mine does it from time to time but its annoying nonetheless.. I don't want to bring it to the dealer since they probably "can't duplicate the problem" because it does it rarely and randomly.. The TSIB doesn't even cover the 09's...
