Supercharged Issues Please Help!
First off, I have a 2015 IS350 (yes I know I posted in the ISF forum) I’m doing this because supercharged ISF’s are far more common than 3IS and I’m hoping this can get more exposure. I’m having an issue where at WOT, the car will either completely cut out (RPM stops going up too) with no throttle response and go really lean (usually 18-22 AFR) before 3.5K RPM, or if I ease past 3.5K and floor it the car will jerk violently until I let off the gas. Both issues stop as soon as I get off the gas. I also recently noticed that from a dead stop if I give the car too much gas there will a jerk, like a misfire and the car will go lean. So it’s not just at WOT that the car is running weird. The jerk isn’t as violent as when I got WOT, however.
I got the supercharger installed two months ago and the car was fine initially after the install. I decided a week after to run ethanol to an E30 blend and the car was still running fine. At this point, I didn’t have an ethanol gauge yet (it was on the way) so I might’ve been a little over, and one night the car completely went into limp mode when I floored it. I had a code for the car running too lean and cleared it as well as filled up a little on pump gas. Afterwards, the car was able to pull again, but I noticed sometimes that at WOT in the upper RPM’s, the car would hesitate briefly before pulling hard again. After another week, the night this issue started happening, I had just added more ethanol to exactly E30 because I got the ethanol gauge installed. It was at E23 before I added more and it pulled amazing up until I added the extra 7%. I’m certain the extra ethanol did something but I don’t know what.
Initially, I thought it was the tune so I got multiple tunes from Rafi and none of them fixed the problem. I even went back to pump gas and the base supercharger tune, which worked before and STILL had the same problems. This leads me to believe it can’t possibly be the tune.
I had new spark plugs installed when I got everything done and I changed them out again today because I thought that was the issue. The old ones I took out today were gapped way too small (.022). The new ones were gapped by Rafi at (.025) but the problem is still there. I also verified the compression on my engine and it’s above specs (210 in five cylinders and 200 in one cylinder). I have no CEL. I asked Rafi about potential fueling issues and according to him, the stock fuel pump and injectors should be more than enough to run ethanol. Strangely, the car will have no problems going to redline with some boost at quarter ish throttle
I have attached some logs that are short because they are only of WOT pulls (about 6-8 each log). The first pull in the log will be the violent jerking. The few pulls afterwards will be the cutting out followed by the throttle closing after the cut out.
I just don’t understand why the car was completely fine before and now I can’t do more than half throttle. Even Rafi is perplexed by all of this. The only thing I haven’t done yet is check my fuel pump, filter, and injectors. Did the ethanol mess up one of those components since the problem is still present even with pump gas? I did notice the chargepipe was extremely loose when doing my plugs so maybe there’s an install error somewhere, or a vacuum/boost leak? But if so, why would the problem show up weeks later? I’m not sure at this point.. I really hope someone can help out or point me in the right direction.
Thank you.
Id check for leaks, if youre saying the charge pipe felt loose than its possible the rest of the piping isnt secured. Could've wiggled out during your pulls (possibly why it was delayed in having issues).
lol
