Figs Differential Mounts
Old Sep 20, 2018 | 09:53 AM
Joker4096's Avatar
Joker4096
Originally Posted by ljdsong
Im looking for any pics how to remove the subframe oem bushing and torque specs for this install. I already tear down the elsd pumpkin. Hoping somebody to chime in for the help.
check out the product page on FIGs website .Instructions are on there.
Old Oct 1, 2018 | 09:46 PM
FIGS's Avatar
FIGS
The Maker
Just a reminder guys, we suggest replacing both pinion mount bushings and the rear mount bushings at the same time. The reason is to match the material properties and prevent stress from displacing onto the other mount if it is not alike. As far as removal goes, the best technique we have found is to make a small slit with an air body saw in the outside factory bushing ring. Do not cut the subframe sheet metal. Once a small slit is formed, use an air chisel to fold and form it inward, peeling it away from the subframe. Continue this process as needed until a single spot is released, removing press tension on the bushing cup. Then it should chisel out the rear. Just be patient as it will take some time and careful pressure applied to the right spot.
Note that we now have 3 different options for rear diff bushings as SuperPro released a version as well that is a little different. The face mount version in 90 duro with our bushings is still the most tested version for the F, but we also have other versions that space the support back into the subframe more for those of you adding more power. Contact us if in doubt, we are here to help.
Also from the Service manual here are the torque specs.
Thanks, Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
1997Soarer
Oct 14, 2018 07:06 AM
FIGS
Jun 15, 2016 08:20 AM
VJZ
32
Feb 4, 2015 06:25 PM
2JTsc300
Jan 15, 2013 08:54 AM
