Need Help! After Market Sub & Amp
I recently had an Alpine MRX-M110 amp (1100W) and two 12w3v3-4 JL subs installed. If I play a hip hop song with strong bass, it sounds great until I turn it up the sound level to around 48 to 52, then it sounds as if the subs are hitting an octave or two higher than what the notes should be. I'm assuming it has to do with the preset equalizer programmed into the system.
I was hoping to see if anyone has run into this problem or knows how I can help resolve this issue.
I live in Utah and no one seems to have an answer. I will be heading to So Cal (Orange County) in April and if anyone knows a shop who could help me out that would be great too, thanks in advanced.
My LPF is already set to 80 Hz, and I dont believe that that is my problem because at a high volumes I loose all of my low notes. Thats not how a LPF is supposed to work.
The subs are rated at 500 W RMS and around 1000 W peak for each sub. And the amp is rated at 1100W RMS so each sub is getting the right amount of power.
I don't see how them being out of phase would cause this?
Initially installed the gain was set to zero and the bass on the equalizer on the head unit was mid way. I turned the head unit down to zero and still did the same thing. I bought a control **** for amplifier and turned it up and down and it would turn the bass up and down and it still would do it when it was turned up really high.
The bass almost completely disappears if you have two subs out of phase from each other (unless it's designed that way or you get extremely lucky) while at the same time you'll still get the vibration. It's easy enough to check. Just switch the wires on one of the subs going to the amp so long as it's in stereo. If it's a mono amp you'll probably need to pull a speaker and check inside the box.
Sorry, it's been years since I thought about my car stereo days and I have no idea of your knowledge base.
I have a similar problem. I get "normal" bass until I crank it up a little bit then it becomes "extra loud" and it's not something you can listen to. Like just big bass not music.
I tried working with the filters but couldn't reach something great. My amp is wired with the signal from the oem amp and I also have a dial to adjust it.
It's because the ML system is set up to lower bass as volume increases to protect the 8" stock sub. So you need a signal line prior to the NAV system, where the signal lines come out and you probably tapped into.
I may not be articulating this too well, but search this forum because there are many threads about this with solutions that will fix the problem fo shizzle
RoMiLex
08-13-14 09:15 PM
kietlander
12
11-18-05 04:08 PM
