Need help...
Old Nov 25, 2014 | 06:45 PM
poorbong's Avatar
poorbong
Default Need help...
Hi guys,
Im looking to downsize to 18in. To all the wheel and offset experts out there; what offsets should i be looking at? What are conservative/aggressive offsets? Thanks in advance!
Old Nov 26, 2014 | 01:00 AM
bnizzle87's Avatar
bnizzle87
Truthfully, I don't think it will waver much from the 19s. I was looking at a set of 18s for the track and autocross events, and conservatively offsets of 38-45 (front) and 45-55 (rear) will be just fine. For a more aggressive approach- again, similar to the 19s- maybe 22-32 (front) and 30-35 (rear) will work, but will most likely need camber and/or skinny tires. There are some who have 18s on the forums, and personally I think it looks good. How it performs will be determined by what you're looking for in terms of sizing for both wheels and tires. In fact, if you're at stock height and if you're leaning towards a more conservative set up without camber or doing other things to make the wheels fit, you can run some wide tires up front. I believe some members have a square set up of 285/40/18 with 18x8.5 +38.
Old Nov 26, 2014 | 10:17 AM
ISF4life's Avatar
ISF4life
Listen to Brian" bnizzle87" he is right. Now if u want Tom's front lip u let me know lolz. I have Wald front is coming soon
Old Nov 26, 2014 | 11:31 AM
ISFpat's Avatar
ISFpat
Really? I just bought a wald lip from LOLM3 the other day, I guess we can be twins now
Old Nov 26, 2014 | 11:33 AM
ISF4life's Avatar
ISF4life
U meant the silver one ? or the one came unpainted ? lolz , we cant be twin lolz your F is white pearl :P
Old Nov 28, 2014 | 07:04 PM
I8ABMR's Avatar
I8ABMR
I have been very seriously looking into a cheap track set of wheels and tires. Can you really mount a 285 in the front ?! I was thinking of buying some cheap Enkeis used and mounting up some Hoosiers or even a set of the Michelin Pilot Sport Cup 2.
I just dont understand members flaming people for asking questions. Who cares if there are multiple threads. It will be ok......we will make it ......
Old Nov 28, 2014 | 07:25 PM
Justind27's Avatar
Justind27
Here's my 18" setup (rim sizes) I'll be ordering soon. Tires will be around front 255/35r18 hankook ventus Evo v12, rear 275/45r18 gforce kdw.
Old Nov 28, 2014 | 07:29 PM
Justind27's Avatar
Justind27
Or if go with a set of enkei pkr 18x8.5 +24 and 18x9.5+25
Old Nov 28, 2014 | 08:40 PM
poorbong's Avatar
poorbong
Im looking at Enkei rpf1 18" but not sure which offsets will be best. I dont want to be too conservative or too aggressive either. My car is lowered on kw v3.
Again, thanks for sharing.
Old Nov 28, 2014 | 11:44 PM
bnizzle87's Avatar
bnizzle87
Originally Posted by I8ABMR
[/B]
I found it hard to believe that 285s could be squeezed in the front wheel wells when I was researching tire and wheel sizes for the track, but it indeed can be done with stock ride height. I know the few that have experimented with sizing are running the 285/35/18 all around.
Old Nov 28, 2014 | 11:48 PM
bnizzle87's Avatar
bnizzle87
The wheel design looks great, but the offsets will put you in a little trouble. Both are extremely aggressive for what the IS F can handle without running camber, increasing ride height, and running spacers. I know a lot of people who want aggressive offsets on our cars, and it's highly unlikely unable to be done without spacers for sure.
Old Nov 29, 2014 | 02:12 PM
Sean's Avatar
Sean
I'm not sure if you've seen this yet, from the drag setup thread, but it might help as far as determining size and offset:
https://www.clublexus.com/forums/is-...ml#post8688350
These particular wheels look pretty good as well.
freak21s2k
Jan 21, 2017 03:13 PM
nonopeno
Mar 30, 2016 05:04 PM
Polkman
IS F (2008-2014)
12
Jan 3, 2014 12:57 PM
Halon
Apr 25, 2013 08:48 AM
tipp
Mar 23, 2010 06:24 AM
