do springs help performance?
The largest benefit of the Penske setup is complete servicability and scability.
The KW setup offers a nice comfort valve for high speed fluid damping, but in general the V3 is not a wide band coilover for the track. Its a performance street coilover for a mostly stock car. That coupled with reuse of stock upper hats limits the dynamic misalignment range as well which makes in not track friendly I would say.
No shock is immune from wearing out and the downside to the OE is that it is not rebuildable. So typically 20-35K between rebuilds is a general number. Penske has stated that one "PROBLEM" they have from a business standpoint is that their shocks just last and last. They will sell to a team and that team never buys rebuild parts because they just keep running the same shocks throughout the whole season.
Just keep in mind it is a system and every component will suffer from the least capable part's performance. Also the tunability implies that someone has to tune it. Adjustments are not trivial for everyone and you can get into some weird modes with bumpsteer and roll center certainly. So its tools that need to be applied appropriately.
Largest differences in setups will be settle time from transition (disruption) and the overall response time on uneven pavement. There are a lot of choices and they all have their place. It depends on what you really want from your suspension and how much you are willing to spend to get it.
KW requires you send them back for rebuild which is a drag, the good new is they will last quite a while before its needed. Bummer though to have to swap stock hats back and have the car down to do it.
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Thanks for your time and explaining some of the engineering, etc. about springs vs. coilover setups...
I totally understand Lobux's point about time spent by Lexus on OEM suspension vs. aftermarket solutions and that driver skill is the most important factor in "speed" around the track.
It does seem however that Penske coilovers are probably the "best" current solution to drop the car a little, ability to "corner balance", and improved performance of the suspension over stock at the track... I just wish it wasn't 2 1/2 x's the price of the KW's!
But I guess I'll just keep saving up and wait till next year.Figs, so if 20-35k mile rebuilds for coilovers are typical, and Penske's seem to last longer, what is your projected/guestimated miles for the Penske's? Also, do the Penske's have to be sent in similiar to KW, or can a rebuild be done by someone local and therefore less downtime?
Mike
I'll pay FIGS. Way easier.
I will post up once we get some time on them.
Fig
I thought about asking you in a PM, but figured your answer might just help someone out as well.... I was set on Penske's initially, but now we may be building a new house in the next few months and so my "IS F Budget" has been dramatically reduced by the wife....
anyway, so I was just thinking about doing the Swift springs for now and possibly someday doing a coilover... (hence this thread) BUT, now I've been considering the BCR's with the Swift spring option... Would you reccomend this as an "improvement" to the 2011 OEM setup? I know they won't be as "good" as the Penske's but how would they compare to just the swift springs/2011 OEM shocks vs. KW V3's for primarily DD duty with approx 6 track days per year? I just want to make sure that if I went this route that I wouldn't be regretting it... any input would be appreciated!
