Trac-Control
Old Feb 28, 2009 | 11:26 PM
Dble Agent's Avatar
Dble Agent
Default Trac-Control
I decided to have some fun tonight at a light.....so I turned off traction control and put the car in sport mode.
Then when the light turned green ...punched it...the tires spun for a a few seconds and I let off the gas ...then did it again.
The Traction control system kicked back in ....is that common.
Does the system reinitialize itself when the driver lets off the accelerator.
or what causes it to reinitialize?
It seemed odd to me ...is that what is suppose to happen?
Old Feb 28, 2009 | 11:53 PM
Reciprocal's Avatar
Reciprocal
I don't know, but it turns back on for me too. The only way around it seems to be to hold the trac button for 3 seconds, and turn off VSC and Trac together, then it sticks.
Old Mar 1, 2009 | 07:09 AM
passnu2's Avatar
passnu2
I think once you hit 30mph or over it turns back on. Its how its designed to work. If you hold the button it will disable VSC/Trac until you turn the car off and back on again.
Old Mar 1, 2009 | 10:17 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
No, you don't have to restart the car. You can turn VSC back on with the switch.
Old Mar 1, 2009 | 10:44 AM
DRE1615's Avatar
DRE1615
Yeah you just have to hold it down like the other guys said to shut it off indefinitely. Pressing it once only turns it off temporarily.
Old Mar 1, 2009 | 11:45 AM
ISFHAHA's Avatar
ISFHAHA
Check your PM - SALES ISSUE
Is it really danger to drive with the VSC and Trac off ?
Old Mar 1, 2009 | 12:03 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^Dangerous only to the extent that you'll lose the electronic driver aids, built into the car to help keep you from overdriving the vehicle. If turned off, and you get a little rambunctious, you could get yourself in trouble and wreck the car. These aids are designed to save you from yourself.
Lou
Old Mar 1, 2009 | 06:57 PM
CDNROCKIES's Avatar
CDNROCKIES
Wow! Some of us need to read our owners manual.
Thanks lobuxracer....as usual you have all the technical info we need.
Old Mar 1, 2009 | 07:15 PM
Dble Agent's Avatar
Dble Agent
I would ...if I had one.. the dealer told me he would order it..(my car didnt have any of the books or even the leather cover that they come in)..but I havent been able to catch him since. I tried ordering one from lexus.com or customer care...but they sent me one from an IS350/250. If anyone knows where I can get a set of manuals for an 08 IS-f for lest than $100 please let me know.
Old Mar 1, 2009 | 10:12 PM
CDNROCKIES's Avatar
CDNROCKIES
Sorry Dbleagent...I wasn't referring to you...I meant that I needed to read the manual because I didn't know how to permanently disable mine either...and I've had mine for 6 months now...lol.
Old Mar 1, 2009 | 10:24 PM
avgj0F's Avatar
avgj0F
Stupid-hot-rod driver is worse than VSC-T off.
Old Mar 1, 2009 | 11:09 PM
Dble Agent's Avatar
Dble Agent
No wories...I just wish i had a manual.
Old Mar 2, 2009 | 01:15 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
This has been the standard operation since the 2007 IS350. Thanks to a great friend at Lexus, I actually swapped out the skid control ECU from a 2007 IS350 into my 2006 IS350 to see if this would work without any other mods because the 2006 required the pedal dance to turn off the VSC. It worked. So, I've known about this for a couple of years.
Old Mar 16, 2009 | 09:23 AM
Evie's Lex's Avatar
Evie's Lex
I have a 2003 ES 300 where is the trac control button - my light is so to ready Trac Off
seve7
Mar 15, 2021 03:12 PM
Dezoris
RC - 1st Gen (2015-present)
Jul 17, 2015 12:46 PM
2GSTony
Dec 7, 2014 09:55 PM
Mac2924
IS F (2008-2014)
Jan 14, 2012 08:27 PM
