Odyssey batteries
Old Apr 1, 2024 | 03:51 PM
silverevo's Avatar
silverevo
Default Odyssey batteries
Anyone tried this battery before?
https://www.summitracing.com/parts/o...HFADcqV_-Nx6cM
Old Apr 1, 2024 | 06:13 PM
tronim's Avatar
tronim
$403 for 840 CCA?
Are you powering extra accessories?!
If not, try out the $248 720 CCA OPTIMA 8025-160 25 RedTop
Old Apr 1, 2024 | 06:31 PM
You get what you pay for. They use pure lead, brass posts etc. quality battery.
Old Apr 1, 2024 | 08:02 PM
RJMacReady's Avatar
RJMacReady
I've ran Odyssey batteries since the mid-2000's. Well worth the money. I run one in my ISF (group size 34), just need need a spacer.
Battery:
Amazon Amazon
Spacer:
Amazon Amazon
Old Apr 1, 2024 | 08:15 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^Instead of a spacer why not just user the correct Group 24 battery❓
Old Apr 2, 2024 | 06:05 AM
CCColtsicehockey's Avatar
CCColtsicehockey
Originally Posted by silverevo
Don't buy the Odyssey if you have a batteries plus around you at all.
https://www.batteriesplus.com/produc...gas/sli24agmdp
The X2 is the same battery made in the same factory and they offer a 4yr warranty instead of a 3yr. I think it might be the last 4 yr warranty out there. I have put the battery in my ISF about a year ago and it still fires up as quick as the day I put it in. I know its not all that long but it has been great. Car has even sat a few times for a month due to work and still fires up zero hesitation.
You can even apply the 10 or 15% off coupons that batteries plus has almost always.
Old Apr 2, 2024 | 08:09 AM
silverevo's Avatar
silverevo
Thank you for this!
Old Apr 2, 2024 | 09:14 AM
shu5892001's Avatar
shu5892001
I have this battery in my GS-F, had the car parked in garage without battery tender for weeks and starts without issue. I used to have an interstate agm battery that failed after 3 years.
Old Apr 2, 2024 | 06:42 PM
RJMacReady's Avatar
RJMacReady
You know, when you asked that question I was like "Wait a minute...why did I choose a different size than stock? I had a reason but maybe I was wrong?"
So I went back and did a quick comparison and figured out why I did.
It's because their Group 34 is 6.2lbs lighter while sharing a same if not better cranking amp rating.
Group 34:
https://www.odysseybattery.com/produ...-34m-pc1500st/
Group 24:
https://www.odysseybattery.com/produ...agm24-battery/
The group 24 has more amp hours, but 6lbs is is 6lbs on a porky car like this. With the spacer, I'll call it a 5.5lb weight shave.
Old Apr 2, 2024 | 07:45 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Jesus. Why would you put a huge pig like that in your car?
All three of my cars have Antigravity batteries, and I can lift them over my head with zero effort. 50 pounds? That's a crime with the batteries available today.
https://www.clublexus.com/forums/is-...l#post10946814
Old Apr 2, 2024 | 07:50 PM
Antigravity doesn't do so well in winter or I would have one.
Old Apr 2, 2024 | 09:15 PM
RJMacReady's Avatar
RJMacReady
No doubt the Li-ion car batteries are a game-changer, I'm just not interested in that tech for my street car batteries.
Appreciate the link, though.
Old May 1, 2024 | 09:59 AM
cpforyou's Avatar
cpforyou
Our cars use Group 24.
Odyssey makes a Group 35 to Group 24 spacer/adapter, Odyssey 22201251 Spacer G34-24.
Does anyone know of any other adapters, conversions, etc for other sizes without having to resort to DIY, for example, Odyssey PC680.
Old May 1, 2024 | 10:20 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
Not much out there for cars. A quick search showed a few concepts you could use, but you'd need to fab it yourself.
Figs offers these: https://shopfigs.com/v5/by-vehicle/c...-3GS-ISF/G1119
But it's not clear if they're made specifically to accommodate a smaller battery.
golferjack
Hybrid Technology
Feb 9, 2021 06:35 AM
TexasGSF
GS F (2016-present)
14
Dec 5, 2020 08:46 AM
OldLs400
Apr 4, 2019 01:31 PM
