IS500 Oil change
Old Aug 12, 2023 | 01:45 PM
  #31
Pittsy's Avatar
Pittsy
Originally Posted by sickpuppy
^^^^Yes, you are correct, but so what❓ Again is says or equivalent and then specifies:
ILSAC GF-6A multigrade engine oil
Recommended viscosity
That oil standard is met by all good oils currently on the market, both Dino and Synthetic.
I don’t disagree with you, I’d rather be putting synth amsoil in, but a point was made to me that it needed to be dino, was just bugging me I didn’t know why.
Old Aug 12, 2023 | 02:20 PM
  #32
arentz07's Avatar
arentz07
Originally Posted by Pittsy
Im right there with you here in Phoenix. The Lexus/toyota genuine oil is conventional, not synthetic.
My dealership uses a synthetic blend 5W-30. Isn't that the same thing as Toyota Genuine Motor Oil?
Old Aug 23, 2023 | 07:30 AM
  #33
snowyblue's Avatar
snowyblue
anybody know of good sites to get oem parts for the 500?
Old Aug 23, 2023 | 07:46 AM
  #34
FisforFucGM's Avatar
FisforFucGM
8th Gear
Default syn or dino
I am old school and have no problem with Dino oils, but I would change every 3,000 miles. Some Dino oils vs synthetic are a little heavier grade for grade. Having said that, I run full synthetic 5w-30 Pennzoil Ultra Platinum with a Toyota/Lexus oil filter and will still never go more than 5,000 for the oil change interval. I will actually more than likely change it closer to 3,000 than 5,000. Lastly, I will NEVER use a non API approved oil in anything with a warranty. Once warranty is up, there are some great oils out there like Amsoil Signiture Series that lack the API certification that I'd use.
Old Aug 25, 2023 | 02:17 PM
  #35
Pittsy's Avatar
Pittsy
Toyota Genuine is traditional, from my understanding.
Old Aug 25, 2023 | 02:23 PM
  #36
arentz07's Avatar
arentz07
OK well my dealership put in a synthetic blend. Not sure what else it would be if not TGMO.
It's kind of a moot point. We all know full synthetic is best.
Old Aug 25, 2023 | 02:24 PM
  #37
Pittsy's Avatar
Pittsy
At our dealer, you have a choice between Toyota Genuine, and Mobil1.
Old Aug 25, 2023 | 02:30 PM
  #38
95bat's Avatar
95bat
akaDigger
UX Models (2019-present)
14
Dec 23, 2021 09:47 AM
KingR413
Sep 16, 2021 03:06 PM
IceSC
Jun 2, 2009 12:31 PM
wjimmy
Jun 23, 2007 12:05 PM
Taka
Dec 12, 2001 01:09 AM
