UX Models (2019-present)
Basic Oil Change
Old Nov 23, 2021 | 07:06 AM
akaDigger's Avatar
akaDigger
10th Gear
Default Basic Oil Change
Hello UXers, this is my first post. Been lurking awhile but I signed up in hopes of getting some input from other UX owners.
My 2019 UX250h is now almost two years old. The Lexus dealership that sold the car did the first oil change at 1 year/ 6500 miles. It's now time for the second oil change which I will be doing myself. I see somewhat contradictory information on the subject.
The owner's manual states that the oil capacity is 4.5 US quarts.
It also shows a representation of the dipstick with indicator marks for gauging the proper oil level.
This representation indicates that any reading where level is above the mark between B and C (above) is excessive oil. (In the C zone)
When my oil was changed at the dealer, 4.5 quarts brought the oil level all the way up to where I have marked C (below)
My question for everyone: Where does the oil level come to on your dipstick when it is at the proper level?
Thanks,
Dan
Old Nov 23, 2021 | 02:04 PM
akaDigger's Avatar
akaDigger
10th Gear
50 views so far. Anyone care to comment?
Old Nov 23, 2021 | 03:16 PM
No need to overthink, drain the oil put on a new filter add the amount stated in the manual. How do you know how much oil the dealer actually put in?
Old Nov 23, 2021 | 04:50 PM
CALtd's Avatar
CALtd
Dealers & oil change mechanics tend to have 50 gal barrels of the different oil types. They rarely fill from 1qt bottles. I bought a 5qt 0-16W bottle. I put all but .5qt in and it read almost to the end of your B range.
Old Nov 23, 2021 | 05:12 PM
akaDigger's Avatar
akaDigger
10th Gear
I got contradicting information from the dealership at the time. When I asked, the service representative said they would have put 4.5 quarts in. Then he said to go by the dipstick.
Old Nov 23, 2021 | 05:16 PM
akaDigger's Avatar
akaDigger
10th Gear
I believe I'll be changing the oil tomorrow if the wife will let me have the car for a few minutes. And provided I have the correct oil filter (90915-YZZN1). I'll know for certain where what amount measures on the stick then.
Old Nov 24, 2021 | 10:03 AM
akaDigger's Avatar
akaDigger
10th Gear
Oil change completed at 10 months, 7000 miles. I drained just over 4.5 qts from the engine. This proves that the dealership service manager was incorrect when he told me 4.5 qts were used. I had already removed 28 oz. of oil after discovering the potential overfill. As instructed, I went with the manual and dipstick.
I imagine that there are a number of customers that would have driven the car overfilled for a year.
I was pleasantly surprised that the oil sump and filter have such easy access, a smallish panel and four screws. Filter is down low where the oil draining from it has nowhere to go but into the pan. Hardest part was getting my floor jack slid in as far as the front, central jacking point. Had to use a second (bottle) jack at the pinch weld jacking point to gain an inch or so for the floor jack to clear.
Old Nov 24, 2021 | 10:08 AM
akaDigger's Avatar
akaDigger
10th Gear
This is the correct filter. The sump drain gasket (washer) is 0.48" ID. Those blue colored washers you see on Amazon are the correct ones. I used a FelPro 70822 but would not recommend them. They are plastic and if you torqued to spec, it would probably break.
Old Nov 24, 2021 | 11:34 AM
CALtd's Avatar
CALtd
I use drive on ramps that solves the jacking problems.
Old Dec 1, 2021 | 12:00 PM
MX73's Avatar
MX73
Thanks,
Dan
Did you wipe and reinsert to get a reading or just pull and said it was overfilled? For whatever reason, Toyota\Lexus dipstick are hard to read. sometimes you'll get two different reading if you flip the dipstick. My thinking is that the dipstick tube has residual oil causing some incorrect readings to mark on the dipstick.
Old Dec 2, 2021 | 07:58 AM
akaDigger's Avatar
akaDigger
10th Gear
If I was not clear enough, the oil level at the time I changed it was just slightly above the A mark. Very easy to read as the oil, with 7000 miles, was beginning to darken and *. I did mention that the level before I changed it was minus the the 28 oz I siphoned out last January, the day after the oil change a the dealer. I used a Power Vac with a 4 oz cup, seven cups full. I used a spray bottle straw on a piece of old oxygen cannula hose inserted down the dipstick tube. I would have taken another 4 oz out but my apparatus would not extend any further into the oil.
In summary, the vehicle left the dealership with 5.5 qts of oil in the crankcase.
* About the dipstick. If you sand the dipstick with some 600 grit sandpaper it will no longer have that "repellant" finish that does make the level of newer, cleaner oil difficult to read.
A side note about the same dealer. My wife's friend was driving her leased Rav4 to Indianapolis,170 miles away. Half way her car began smoking badly. The dealer technician had failed to re-install the oil filler cap bathing the engine in oil. not knowing what had happened, she had it towed to a close by Toyota dealer who rectified the issue and cleaned her car's engine compartment. Maybe we got the same technician.
Old Dec 2, 2021 | 08:04 AM
MX73's Avatar
MX73
If I was not clear enough, the oil level at the time I changed it was just slightly above the A mark. Very easy to read as the oil, with 7000 miles, was beginning to darken. I did mention that the level before I changed it was minus the the 28 oz I siphoned out last January, the day after the oil change a the dealer. I used a Power Vac with a 4 oz cup, seven cups full. I used a spray bottle straw on a piece of old oxygen cannula hose inserted down the dipstick tube. I would have taken another 4 oz out but my apparatus would not extend any further into the oil.
Slightly over "A" is nothing. Most places will round up since 1/4-1/2 quart of oil isn't harmful. Being over towards "C" is a serious issue and neglect by the tech.
Old Dec 22, 2021 | 12:19 PM
ViktorG's Avatar
ViktorG
Hi all,
I am a Lexus Master Technician and I am creating a series of maintenance tutorial videos covering the 2019-2022 Lexus UX models.
Here is my video showing how to replace the engine oil and filter on UX250h models.
Please hit me up with suggestion on what other things you would like to see in the video comments.
Cheers!
Viktor
Old Dec 22, 2021 | 03:20 PM
akaDigger's Avatar
akaDigger
10th Gear
Well done, Viktor! This video would be useful to any first timer on this vehicle.
Old Dec 23, 2021 | 09:47 AM
E46CT's Avatar
E46CT
FWIW both of my brand new 2021 ES from the factory had the oil levels higher than the C mark and yep checked 5 min after shut down. doesn't bug me one bit.
Just drain all the oil out and pour in what the manual says. w/ a dry filter, it'll be the 4.5 qt per the manual. as said don't overthink it. the car is a very dynamic place and everything sloshes around continually.
ThumperPup
Apr 18, 2025 09:41 PM
woodranch
RC F (2015-present)
380
Oct 8, 2023 02:59 PM
AMIRZA786
May 17, 2022 02:11 PM
KingR413
Sep 16, 2021 03:06 PM
BBoyM3
RC F (2015-present)
Apr 24, 2015 07:47 AM
