Access System with Elec. Key malfunction
Old Feb 12, 2022 | 06:34 AM
Nilo955's Avatar
Nilo955
Default Access System with Elec. Key malfunction
Not sure if anyone can help me solve this issue. After a week of not driving my 2017 IS I go to start it & it won’t crank. I even changed battery & remote battery still nothing. Hoping to avoid towing to dealer. Any suggestions are Appreciated
Old Feb 12, 2022 | 08:38 AM
kj07xk's Avatar
kj07xk
Did you charge the battery? A new battery doesn’t mean it has a decent charge on it, it may have been sitting on a shelf for 6 months.
Old Feb 12, 2022 | 08:50 AM
Nilo955's Avatar
Nilo955
no I didn’t charge it I tried to jump it though. I’ll take it to get charged
Old Feb 12, 2022 | 09:26 AM
Nilo955's Avatar
Nilo955
battery is fully charged
Old Feb 12, 2022 | 09:32 AM
wthrman2's Avatar
wthrman2
^^ To me, it appears that it isn't a battery issue and may require a trip to the dealer. Mind you, there are some fairly tech savvy folks here so maybe someone can chime in
Old Feb 12, 2022 | 09:56 AM
Nilo955's Avatar
Nilo955
Correct I might have to tow to the dealer. Just hoping someone has dealt with this issue or a tech savvy person can give me suggestions
Old Feb 12, 2022 | 02:13 PM
95bat's Avatar
95bat
Obvious question, but what did the owners manual say?
Old Feb 12, 2022 | 02:37 PM
Nilo955's Avatar
Nilo955
bring to dealer for service that’s all it says
Old Feb 12, 2022 | 06:00 PM
95bat's Avatar
95bat
Well that is super helpful. Is there a way to physically start it with the key? I am new to the IS line so I'm not sure. I thought these cars had a backup start method in case the remote died.
Old Feb 12, 2022 | 06:08 PM
95bat's Avatar
95bat
Found this, don't see another method.
Old Feb 12, 2022 | 07:19 PM
Nilo955's Avatar
Nilo955
my fob battery isn’t dead so putting it on the start button doesn’t work for my situation even though I did try it. Not sure what my issue is will probably have to tow to the dealer if I can’t find a solution
Old Feb 12, 2022 | 08:02 PM
dojoman's Avatar
dojoman
Do you have another key?
Old Feb 12, 2022 | 08:14 PM
Nilo955's Avatar
Nilo955
yes I do….
Old Feb 12, 2022 | 08:19 PM
95bat's Avatar
95bat
Maybe they can give suggestions over the phone. I also found this after a google search:
When the electronic key does not work properly
  • Make sure that the smart access system with push-button start has not been deactivated using the Remote Touch or at your Lexus dealer. If it is off, turn the function on.
  • Check if battery-saving mode is set. If it is set, cancel the function.
Maybe you had the key in your pocket or something and accidentally mashed the buttons and put it in battery saving mode? The interwebs says to disable power saving mode, just press any button on the key fob.
I didn't find anything on deactivating or reactivating the smart access system.
Old Feb 13, 2022 | 12:44 AM
Nilo955's Avatar
Nilo955
i have 2 keys, car hadn’t been driven for about a week. Tried both same issue I’ll call Lexus Monday
