AC suddenly not working
Old Nov 6, 2021 | 01:20 AM
Zerotec's Avatar
Zerotec
Default AC suddenly not working
AC was working fine about 2 hours ago but suddenly stopped flowing air out of the vents on my way home just now. Defrosters work as normal but when switching to the other modes it doesn’t want to push any air out. It sounds like it but isn’t. Going to attach a video below.
Any help appreciated.
Video:
https://imgur.com/a/TZx0nTg
Old Nov 6, 2021 | 07:07 AM
Sasnuke's Avatar
Sasnuke
Sounds like a servo motor issue where it's not moving the doors to the proper position you want.
Old Nov 6, 2021 | 01:41 PM
Zerotec's Avatar
Zerotec
How much of a hassle is a fix such as this? Cost?
Edit: That is so weird. Went into my car to try a couple things out and now it’s working fine? I’m not complaining by any means but is there any reason why it stopped working in the first place?
Old Nov 7, 2021 | 07:54 AM
Sasnuke's Avatar
Sasnuke
The servo may have been momentarily stuck. There are several servos in the HVAC system that control hat and cold, mode position for where to blow the air, and the dual zone functions.
There was a special service campaign for the servos if they were causing issues.
You may want to inquire with your local dealer...you are likely eligible.
Old Nov 7, 2021 | 12:40 PM
Zerotec's Avatar
Zerotec
Okay great! I’ll go ahead and contact them. Thank you!
Old Nov 7, 2021 | 06:39 PM
wongnee's Avatar
wongnee
try this:
disconnect the -ve and let the car sit for 15-20 mins.
then plug the -ve back and try restarting the car and see if that helps.
Old Nov 7, 2021 | 07:22 PM
Zerotec's Avatar
Zerotec
Originally Posted by wongnee
try this:
If it happens again, I'll for sure try this first.
Old Nov 8, 2021 | 04:31 AM
Sasnuke's Avatar
Sasnuke
try this:
What was suggested will work, but it's only a temporary fix to the underlying issue.
By disconnecting the battery it simply resets the servo motors...so they should work fine after until the issue occurs again.
Eventually when the servo fails then replacement will be the only fix. As part of the service campaign they also reprogram the AC Amplifier (ECU).
Old Nov 10, 2021 | 01:31 PM
Zerotec's Avatar
Zerotec
Does the service campaign have a time limit? Or is it more whenever it happens, if your car is under the list that is under the "warranty", they will fix it?
Old Nov 10, 2021 | 03:21 PM
Sasnuke's Avatar
Sasnuke
The service campaign is fairly new...each one will have it's own expiry date.
Some are a couple years, some a decade, some never expire...it really depends.
Check this thread for more information: https://www.clublexus.com/forums/is-...vo-motors.html
Old Nov 18, 2021 | 06:12 PM
Zerotec's Avatar
Zerotec
Just called today and the service campaign (at least for my model) ends January 12th, 2022. Thankfully this all happened just in time!
Last edited by Zerotec; Nov 18, 2021 at 07:07 PM. Reason: put 2021 instead of 2022
Old Nov 18, 2021 | 06:27 PM
Sasnuke's Avatar
Sasnuke
Just called today and the service campaign (at least for my model) ends January 12th, 2021. Thankfully this all happened just in time!
Finally a lucky break...no pun intended. I think you meant 2022 .
Old Nov 18, 2021 | 07:08 PM
Zerotec's Avatar
Zerotec
Literally! And whoops, didn't even realize that!
Jlacck
Sep 5, 2015 01:57 PM
Tantrix
Mar 16, 2015 09:30 PM
JML311
Jul 20, 2013 05:52 PM
SpencerT
May 5, 2012 04:48 PM
XSTeknique
Jun 7, 2006 12:40 PM
