Help! Door Won’t Open!
Old Jan 19, 2021 | 06:12 PM
GnueyM's Avatar
GnueyM
Default Help! Door Won’t Open!
Hello,
I have a 2015 IS350 and the battery is dead. Popped out the manual key from the fob and the key won’t even turn! Is there something I’m doing wrong?
Thanks in advance!
Old Jan 19, 2021 | 06:34 PM
Sasnuke's Avatar
Sasnuke
It's possible the key cylinder is stuck or seized from lack of use...or...that isn't the correct key.
Did you try the key in the trunk to see if it works there?
Old Jan 19, 2021 | 06:38 PM
GnueyM's Avatar
GnueyM
Sorry to sound like a newbie but where is the manual key hole for the trunk on our cars?
Old Jan 19, 2021 | 06:50 PM
Sasnuke's Avatar
Sasnuke
Look under the edge of the trunk where the license plate lights and trunk opener button are...the manual key cylinder is on the left side.
Old Jan 19, 2021 | 07:06 PM
GnueyM's Avatar
GnueyM
Thanks! Found it! Key also doesn’t turn there as well. I’m assuming this means I was given the wrong key from the dealership?
Old Jan 19, 2021 | 07:19 PM
Sasnuke's Avatar
Sasnuke
The likelihood of both cylinders being seized is a little unlikely.
Is it an original Smart Key (one of the two the vehicle is delivered with), or is it an additional key the dealer provided?
The metal key has to be laser cut to the correct key code.
If you contact the dealer they should be able to find the key code for the vehicle and get a key cut, or cut the one you have if it's uncut.
Which is another question, is the metal even cut? It would look like an inverted cut key, where the teeth are on the inside.
Old Jan 19, 2021 | 07:37 PM
GnueyM's Avatar
GnueyM
It’s an original from the dealer and it is already cut as well. Seems quite odd that it won’t work. I’ll contact the dealership though. Thanks for your help!
Old Jan 19, 2021 | 07:42 PM
Sasnuke's Avatar
Sasnuke
If you have some penetrating fluid, spray it directly into the key cylinder...if the cylinder is seized, it should help it loosen up.
mvblum
RC - 1st Gen (2015-present)
Feb 6, 2021 09:51 AM
Andyb63
May 19, 2020 01:51 PM
LS430cb
Aug 4, 2016 06:05 PM
3rdelement
IS - 1st Gen (2001-2005)
Jul 17, 2009 11:55 PM
StillHere
Dec 20, 2008 11:59 AM
