Squeaking poly CAB's
Old Feb 19, 2020 | 12:28 PM
igetit14is's Avatar
igetit14is
Default Squeaking poly CAB's
Has anyone had a problem with RRRacings bushings squeaking like crazy and if so what did you do about it?
Had on my car for about a year, they started squeaking six months or so ago, pulled them out lubed what i could lube, and they still squeak like crazy,,
open to suggestions
Old Feb 19, 2020 | 01:07 PM
s3v3n's Avatar
s3v3n
open to suggestions
Check out this thread;
https://www.clublexus.com/forums/is-...squeaking.html
Old Feb 19, 2020 | 02:13 PM
RRRacing's Avatar
RRRacing
Sponsor
open to suggestions
is your car AWD or RWD?
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Online Store: www.RR-Racing.com
Email: Contact@RR-Racing.com
Phone: 484-756-1777
Facebook : Youtube
Old Feb 19, 2020 | 02:23 PM
igetit14is's Avatar
igetit14is
Rafi
Hey Rafi,
its RWD, been emailing Simon all morning, I'm going to put the oem bushings back in to see what happens and go from there,
Old Feb 20, 2020 | 12:35 PM
E46CT's Avatar
E46CT
We went through this for quite a few years, possibly a decade, over at the BMW side of things about 10 years ago. I told everyone it's not worth the time, effort, money going poly on a part clearly designed for street-use. Rough handling, and even dangerous handling can result. One of the premier BMW race car building teams wrote an article on it too. Pretty interesting read. And they're a hardcore race team. They hate the things on street cars.
All that aside from the obvious maintenance/annoyances the squeaks can create.
Your car should work for you, not the other way around.
I can write a small book on this topic but that's the gist of my thoughts on this after many years of experience and trying most mods under the sun.
If you drive on reasonable roads, best case scenario, you can get away with the poly bushings (in this location) but you will have to babysit them on some unreasonable interval.
Old Feb 20, 2020 | 02:22 PM
dteskmo's Avatar
dteskmo
open to suggestions
I and others have had that problem with the USRS bushings. Switch to FIGS bushings. You will find they don't squeak and have less NVH.
Old Feb 20, 2020 | 02:43 PM
Tungstn-IS's Avatar
Tungstn-IS
I had the FIG's in my previous IS', and never had any issues over years of usage. It seems the thrust washer set up on the RR bushing would completely eliminate deflection of the LCA (which others will not), but also create a high concentration of friction on the poly to washer surface as it is loaded. Everything in suspension tuning is a balance/compromise.
luciano
Suspension and Brakes
88
Dec 14, 2015 10:19 AM
iGOTlexy
Aug 8, 2012 07:05 AM
vwynn
Apr 24, 2011 11:03 AM
nthach
Oct 3, 2007 02:50 PM
DropTop430
Apr 25, 2002 06:27 AM
