Wheel setup
Old Apr 18, 2019 | 01:08 PM
anguyen3's Avatar
anguyen3
Default Wheel setup
Hey guys, I'm looking to get rims for my 2016 IS300.
What size tires do you guys recommend?
I was looking to run 20x10 rims and 255x35 tires. Is that an ok setup?
Old Apr 18, 2019 | 02:07 PM
AVIAT0R's Avatar
AVIAT0R
Hi anguyen. Try searching in this thread: https://www.clublexus.com/forums/is-...exclusive.html
Lots of fitments in there.
Old Apr 18, 2019 | 03:28 PM
TOPENDMS's Avatar
TOPENDMS
Former Sponsor
You can’t fit x10 up front.
I suggest:
19x9 +32 225/35
19x9.5 +40 255/30
20s I would do:
20x9 +32. 225/35
20x9.5 +40 255/30
Old Apr 18, 2019 | 05:18 PM
Sasnuke's Avatar
Sasnuke
Stick with 19's...20's is too big in terms of fitting a decent sidewall tire.
Recommend:
Front: 19x8.5 +35 - 235/35/19
Rear: 19x9.5 +40 - 265/30/19
You can vary the offset by +/-2
Tire size can go down to 225 and 255.
Old Apr 18, 2019 | 05:48 PM
SilvaIS350's Avatar
SilvaIS350
Recommend:
perfect set up! This won’t rub and it won’t rub if you lower your car.
Old Apr 18, 2019 | 10:28 PM
AVIAT0R's Avatar
AVIAT0R
Yeah Sasnuke has the perfect sizes listed.
On another note, what are the most popular tire sizes for 18, 19, and 20 inch rims. I would be interested in learning. I think for 18 inch the most popular size is 225 40 18 right?
Old Apr 19, 2019 | 07:30 AM
Sasnuke's Avatar
Sasnuke
Here is rim/tire fitment list for 19's that I posted elsewhere:
Stock F-Sport Wheel specs
18X8 +40 225/40/18
18X8.5 +50 255/35/18
19 inch upgrade with staggered fitment (to keep the exact same tire circumference as the stock 18 inch wheels - no offset as that is wheel manufacturer specific):
19X8.5 225/35/19
19X9.5 255/30/19
19 inch upgrade with staggered fitment - with plus size on tires:
19X8.5 235/35/19
19X9.5 265/30/19
19 inch upgrade with staggered fitment - with plus plus size on tires:
19X8.5 245/35/19
19X9.5 275/30/19
For 20's depends on width of the rim, but you're looking at 225/30, 235/30, or 245/30. Any bigger and you'll likely have rubbing everywhere.
Old Apr 19, 2019 | 09:59 AM
AVIAT0R's Avatar
AVIAT0R
Thank you Sasnuke, that is very helpful!
Old Apr 24, 2019 | 12:15 PM
anguyen3's Avatar
anguyen3
Recommend:
Alright so 20x10 square set up definitely isn't a good idea right?
Old Apr 24, 2019 | 12:17 PM
JoeyW001's Avatar
JoeyW001
18X8 +40 225/40/18
19X8.5 225/35/19
19X9.5 255/30/19
19X8.5 235/35/19
19X9.5 265/30/19
19X8.5 245/35/19
19X9.5 275/30/19
Is this considering if the car is being lowered? OP might not be lowering, 20inch doesnt seem that far fetched to have rubbing
Old Apr 24, 2019 | 01:06 PM
Sasnuke's Avatar
Sasnuke
It's not any kind of idea...it just won't fit...on the front at least.
You could do a 20x10 on the rear with an offset around +45...depending on what the rim manufacturer offers.
The front would be a 8.5 or 9.
The front can't fit a 9.5 in any rim height, so a 10 is out for sure.
Old Apr 24, 2019 | 01:08 PM
anguyen3's Avatar
anguyen3
Ahh alright that makes sense. So I'm considering that setup you recommended but the rims I'm getting only has 19x8.5 and 19x10. Would the tire setup still fit?
These are the rims here:
http://www.nicheroadwheels.com/essen-m147-w-12799.htm
Old Apr 24, 2019 | 01:09 PM
Sasnuke's Avatar
Sasnuke
Those specs I posted would work either with stock height or lowered.
The key is the offset, which isn't included due to dependency on what the manufacturer offers.
Some have fixed offsets, and some say they will make the rim with whatever offset you want.
You can definitely fit 20's, but the width is the issue when going with a square setup.
Can't have wide on the rear and front. You'll be basically buying rims that fit the front when you go square.
You'll see by my signature I have 20's.
Old Apr 24, 2019 | 01:30 PM
Sasnuke's Avatar
Sasnuke
You can use the last 2 tire setups from the list I provided.
In looking at the link you provided for the rims, the front looks good...19x8.5 +35.
The rear might be an issue if you're doing the 19x10, since the offset is only +40.
If it was a 19x.9.5 +40, then I would suggest the 255 tire for the rear and you should be good to go.
The 19x10 +40, even with the 265 tire, is likely gonna rub at stock height on big dips or with passengers. Lowered it's gonna rub.
LexusK
May 15, 2025 09:29 AM
myLexRX
Nov 5, 2017 05:04 PM
100degrees
Wheels, Tires & Brakes Forum
Jun 13, 2012 04:29 AM
zetec2vtec
Jul 8, 2009 06:38 PM
Mr.BigDanD
Aug 30, 2006 03:20 PM
